So I Got This Tracker...Moonfish... Now What?
  • 19 Replies
  • 4866 Views
Offline ShapeShifter
  • 151
  • Blaming the media for the demise of our culture...
« on: January 29, 2011, 09:23:07 AM »
I once built an 87 Sammy with a 1.6 so I am not new to the Suzuki world, but a Chevy Tracker...?  What is it really?
I picked up a nice 2000 Tracker with 2.0.  VIN says it was made in Canada but so was my Toyota.  Is my Chevy Tracker the same as a 'Zooki?
The little truck is nice and the 235/17 tires rub more than Peewee Herman in a movie theater.  I will also need some gears but here are my questions:
This baby is an automatic.  That's right, and A/C too.  Will the xfer case gear kits available work with an auto shifter?
Will the Rockey Road 2" body lift clear the 235/17 tires?
What else should I do to it to build a tasteful rig?
Any help or input woul be great!
« Last Edit: January 30, 2011, 09:40:42 PM by ShapeShifter »
Offline jeff1997
  • 1228
  • 27
Re: So I Got This Tracker.... Now What?
« Reply #1 on: January 29, 2011, 09:24:42 AM »
Love the rims!! The first thing you need is my 2" coil/strut spacer lift to help clear the tires.  ;)
3" Masterkit1 body lift
Custom strut spacers
  • 151
« Reply #2 on: January 29, 2011, 10:13:55 AM »
That is indeed a possibility.  I would like to smooth out the ride too.  Has anyone used your kit with OME springs?
Offline jeff1997
  • 1228
  • 27
« Reply #3 on: January 29, 2011, 11:46:29 AM »
Yes, although the spacers and the OME springs will give it too much lift for the CV's to handle. Some guys have used OME springs and 1" in front and 1.5" spacers in rear.
  • 151
« Reply #4 on: January 29, 2011, 01:44:58 PM »
Oh.  I thought I could get OME stock legnth springs....
Know anything about auto trannys?  Is the xfer case the same as manual?
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #5 on: January 29, 2011, 04:41:03 PM »
Very nice looking Tracker.  Calmini's transfer case gears state they all manual non-V6 transfer cases... so it appears they wouldn't work on yours and their site indicates their gears are currently not available anyway.  http://www.puresuzuki.com/rockcrawler2.htm
OME springs will give you (according to their info) about 1.5" of lift.  I had a set on one of my trucks and they lifted it the same as Jeff's coil spacer lift did on another one of my trucks which is right at 2 ".
A little bit of rub at full lock is normal with 235 series tires and larger.  Big side wall lugs increase the rumble when you turn tightly. Those rims appear to be aftermarket rims and are probably 7" wide or better.  They will increase the amount of rub you experience as well.
« Last Edit: January 29, 2011, 05:11:03 PM by nprecon »
  • 151
« Reply #6 on: January 29, 2011, 05:03:52 PM »
Thanks for the input.  I notice TrailTough has a gear set but I will have to wait until Mon to talk to Brant.
How did you like the the OME springs as a straight swap?  Did it improve the ride?  Which ones did you get, medium?
As for my tires/wheels, I wonder if 2" or even 2.5" of lift would actually lessen the rub.  I bought it like this so I am not sure of the backspacing..
Offline nprecon
  • 2318
  • 52
« Reply #7 on: January 29, 2011, 05:14:36 PM »
The OME springs totally changed the ride.  They were very nice... even though I didn't run their struts and shocks.  I sold my Tracker with the OME springs on it but I do intend to outfit Buster (my Tracker) with a full OME suspension this summer.  The ride was just too damned nice.  I know I could soften my current ride by running less air in my tires... but that's just the way i roll!!  I had MEDIUM springs in the front.  I have a #35-40 brush guard on the front of my truck now but i think I will still go with the medium springs.
Oh yeah, and even though it is a Tracker, if you pop the hood you're gonna see the word "Suzuki" on an awful lot of parts, like the air cleaner box for starters.
« Last Edit: January 29, 2011, 05:17:19 PM by nprecon »
  • 151
« Reply #8 on: January 29, 2011, 05:37:47 PM »
Do you have a link with a pic of your brush guard?
Offline nprecon
  • 2318
  • 52
« Reply #9 on: January 29, 2011, 11:01:01 PM »
Link is in the search engine.
  • 151
« Reply #10 on: January 30, 2011, 08:36:04 AM »
Thanks.  Yeah.....no offense but the search engine on this site is crap.  In my search I did however find the black plastic reconditioner you recommended.  That will come in handy as my bumpers are greyed out..
  • 151
Re: So I Got This Tracker..The Moon Fish... Now What?
« Reply #11 on: January 30, 2011, 09:39:56 PM »
I have decided to name it "Moonfish".
Offline nprecon
  • 2318
  • 52
Re: So I Got This Tracker...Moonfish... Now What?
« Reply #12 on: January 31, 2011, 06:19:00 PM »
Oh yeah... "Forever Black", thanks for bringing that up!  I put that on my fenders back in the fall of '07 (as I recall) and it is just now starting to fade and needs another application this spring (2011).  So guys and gals although it says "forever black"... apparently isn't.  However, it did last me a full 3 years and I can get two full applications from one bottle so I still consider it a very good product.  It outlasts the others by far.  The other option would be to simply spray paint the bumper covers a flat black with a rattle can.  I know some dealers actually do this.  I suppose the results would last as well and it would also be an easy touch-up.
  • 151
« Reply #13 on: January 31, 2011, 06:22:46 PM »
I considered trying Krylon Fusion paint.  I think they make a satin Black.  I will swear by Fusion paint as it sticks to dirt bike plasics and coats like a factory finish.  And it withstands flexing too.
Offline nprecon
  • 2318
  • 52
« Reply #14 on: January 31, 2011, 06:44:45 PM »
True.  Another nice feature Forever Black would have over rattle cans is you don't have to mask off all your truck body to apply it and you can easily wipe excess off the paint.  When you start darkening your side vinyl, door handles and mirrors masking would be come more of a chore for spray paint.  Not a big deal, but a consideration.
