Missing Teeth Pinion / Ring Gear (98 Kick 4dr Sport)
  • 9 Replies
  • 4776 Views
Offline Dennis .89-
  • 54
  • I Owe I Owe, So Off To Work I Go!!
« on: January 30, 2011, 01:23:17 PM »
I started to hear a knocking sound coming from my rear diff a while ago and ever since i stop driving and
i ordered a rear lockright locker and i finally got around to getting the rear diff disassembled and found out
that i broke off 2 full teeth on the pinion and two chips off the ring gear. and now my problem is i cant find
a replacement because calmini has them temp discontinued. and they don't have stock ones only the 13.5%
reduction ones and that would mean i would have to replace both front and rear. other problem is i went to
local stores in my city and no one will bring anything in for an imported sidekick only domestic cars.
any one know where i can get a stock ring and pinion out of a 1998 Sidekick Sport?
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
Re: Missing Teeth Pinion / Ring Gear (98 Kick 4dr Sport)
« Reply #1 on: January 30, 2011, 02:15:09 PM »
give hawks a try 1-888-726-8724 they seem to have it all
87sami 32" bfg mt 6.5:1 w/reverse S shifter  1.6 16v sold and missed
Offline Skyhiranger
  • 3734
  • 122
« Reply #2 on: January 30, 2011, 08:28:36 PM »
So have you got stock gears in there, or the 5.83 aftermarket gears that they used to sell?  Stock gears should be 5.12s (41 teeth on the ring, 8 teeth on the pinion).
I probably have a complete 5.12 rear third around here for your sport.  Yours has rear ABS right (electrical connector on the rear third)?
Offline Dennis .89-
  • 54
« Reply #3 on: January 30, 2011, 10:43:05 PM »
ummm there the stock ones the 5.12 i think i haven't done any research but i know for a fact there stock
how much could you let them go for?
i also live in canada alberta.
Offline Skyhiranger
  • 3734
  • 122
« Reply #4 on: January 31, 2011, 05:16:58 AM »
I'll PM you some info.
Offline smife
  • 179
« Reply #5 on: January 31, 2011, 06:56:30 PM »
I have a rear out of a 96 Sport. The third I have does not have the electrical connector on it. The Sport I had, had the ABS on the end of each axle by the brakes. PM me if you need it.
Offline joe dirt
  • 148
« Reply #6 on: February 01, 2011, 10:11:10 AM »
no abs ring behind the ring gear...that means no abs in the third member...although you knew that, lol..just keeping you on your toes!!...lol
" you like them spinn'n tires "
87 sami with yota axles...529 gears...spool rear...lockrite front...3-link and volvo coils....rears up front shackle reversal...4:16:1 t-case gears...34/10.50 ltb's.....diy beadlocks....
Offline Skyhiranger
  • 3734
  • 122
« Reply #7 on: February 01, 2011, 10:21:03 AM »
LOL.  I don't deal with sports enough to remember all the different details on them.  I know they all have 4 wheel ABS, I just didn't remember where the rear sensor(s) were located.  ;)
Offline mojoincolorado
  • 95
  • I love YaBB 1G - SP1!
« Reply #8 on: February 01, 2011, 07:25:06 PM »
I see 8 pinion teeth.
How many ring gear teeth?  Ring/pinion= ratio.
Offline Dennis .89-
  • 54
« Reply #9 on: February 01, 2011, 10:06:07 PM »
8 pinion : 41 Ring Gear
