Automatic Transmission upgrade options?
  • 3439 Views
Offline yellow2000S/R
  • 152
« on: February 02, 2011, 02:14:17 AM »
SO, with my rods coming in a few weeks, I'm sending the honda crank for the nitride treating soon as well. Then it's a matter of many measurements, bearings, gaskets, and assembly and it's ready to go together.
My question is, I have a 3spd auto and am wondering what issues I could look forward to. I have 5.13 gears swapped in place of my stock 4.30 gears. I currently only have 30" tires but plan on going 33s. I'm only starting on a tb25 turbo from a Saab with maybe 6psi and 91+ octane till I get some engine management. With all I've invested in this engine build (rougly $3k), I WILL be upgrading to a larger turbo and standalone.
Any transfercase issues?
« Last Edit: February 02, 2011, 02:19:28 AM by yellow2000S/R »
Re: Automatic Transmission upgrade options?
« Reply #1 on: February 02, 2011, 04:40:34 AM »
All my driveline parts seem to hold up fine to the extra HP with the turbo. Just make sure there all in good shape to begin with and maybe add a trans cooler. The Trans cooler is always a good idea with the auto.
Offline chevymagoo
  • 18
« Reply #2 on: February 03, 2011, 04:40:38 PM »
where do you guys put the auxillary cooler and where how hard is it to install one?
95 Geo Tracker Hardtop Automatic 4x4 2 Door LSI  107000 miles homeade 2.5 inch lift and 30 x 9.5s
« Reply #3 on: February 03, 2011, 07:08:16 PM »
Mines mounted right above my winch in my Calmini bumper in front of the grill. I need to find a better place for it though, I think it blocks too much air when going slow. If you can install a turbo you can install a trans cooler, it may be a bit messy but quite easy.
  • 152
« Reply #4 on: February 03, 2011, 10:31:39 PM »
Good call on the trans cooler, I was thinking about a small one not long ago but it slipped my mind. I plan on routing it through the trans cooler then through the 'factory' cooler built into the radiator to warm/cool it slightly so it's consistent. I've read that's a good idea a few times on other sites.
Offline Jluck
  • 1389
  • 40
« Reply #5 on: February 03, 2011, 10:34:39 PM »
while your at it you could put a remote style oil filter on it too. can never have too clean and cool of tranny oil. a regular aux type oil filter works great and easy to service too.
