Suzuki Sidekick, Vitara, Geo Tracker (Gen. 1 Platform) 1989-1998
mustang injector in sidekick?
jump454
10
February 03, 2011, 07:25:41 PM »
i have a lifted 95 jlx. my number 2 injector is bad. anyone have any idea if a ford mustang injector would fit? from what ive read there aprox. 19lb injectors in the zuk and mustangs are the same. i have access to some of them and thats why im asking. thanks for any input.
Drone637
8121
116
Evil Cow
Re: mustang injector in sidekick?
February 05, 2011, 03:31:55 PM »
I have heard you can swap in a Nissan injector, but nothing about a Mustang. You should give Hawk Suzuki a call, they sell used injectors that come with a guarantee.
jump454
10
February 05, 2011, 03:35:25 PM »
ok thanks. i have mustang injectors laying around and wanted to see if anyone had tried them. ill give them a call. thanks for the info man.
great08
10
Reply #3 on:
November 11, 2011, 12:09:00 PM »
The only thing I know about injectors is that their size is directly related to the amount of HP that cylinder is going to be producing. So if they are from an engine that has too much lager of a displacement... then you could have a problem.
Unless the particular injecter you have is able to open and close fast enough. (I think they were called "low impedence")Those types of injectors are typically used on turbo'ed cars. So that they can pump out a small amount of fuel when the car is not under boost... then a larger amount when the engine is under boost.
Marty
