Swapping a 2.0 for a 2.3 Aerio Engine?
  • 10 Replies
  • 6955 Views
Offline ShapeShifter
  • 151
  • Blaming the media for the demise of our culture...
« on: February 06, 2011, 08:04:56 AM »
Has anyone ever tried this?
I read that the 2.3 was an evolution of the 2.0....
Offline Frank84
  • 176
Re: Swapping a 2.0 for a 2.3 Aerio Engine?
« Reply #1 on: February 07, 2011, 02:18:48 PM »
I always wondered that as well.  Is the 2.3 transverse in the Aerio?
2001 2 Door Tracker, 4x4, 2.0, 5 speed, 215/75/15
Jeff's 2" lift, OME shocks/struts, Sh*t on the fly removed, warn hubs
  • 151
« Reply #2 on: February 07, 2011, 07:41:02 PM »
Good point.  I suppose that means it's impossible?
« Reply #3 on: February 07, 2011, 09:11:51 PM »
No it means you have to make it fit.  Rumor is that you change out the oil pump, pickup tube & pan, intake and exhaust manifolds and create a set of mounts.  Make up a few missing steps, try using your ecm, or integrate the aerio into your rig.
Plan on a little extra time chasing gremlins.  STAY AWAY from the CAN BUS, it needs computers in communication.
« Last Edit: February 07, 2011, 09:21:50 PM by BRD HNTR »
« Reply #4 on: February 24, 2011, 10:03:31 AM »
i got it done in my 2001 tracker wroks great
Offline samuraidan
  • 196
  • speak softly, and carry a big stick
    • City Ranger
« Reply #5 on: February 24, 2011, 10:46:17 AM »
I apologize for my ignorance, but wouldn't it be a lot easier to swap in the 2.5 six? or if that's not enough the 2.7?
'00 Vitara 2.0L 5spd w/ Jeff's lift, SR Customs body lift, 5.13's, rear locker, SR Customs steel pinion collar, 1.25" wheel spacers, 15x7, 31x10.5R15 Dynapro MT's.
« Reply #6 on: February 24, 2011, 12:12:59 PM »
Easier - no - better - maybe.
The 2.3 is, so to speak, the next iteration of the 2.0 J20, you can probably just drop it in and bolt it up, and do a little bit of futzing around with the intake & exhaust and you're done - they're very similar in terms of engine management electronics
The V6 on the other hand is a different transmission, different manifolds, different ECU and harness - it's definitely more work, you probably will get more power and torque out of it than you would the 2.3, so it might be worth the extra work though.
« Reply #7 on: February 24, 2011, 01:17:11 PM »
The 2.7 is MUCH tighter, a little heavier, more wiring...  With more power.  The 2.7 only comes with Automatics (not that that can't be changed).  2005 and later use a CAN Bus, and computers (ECM, TRANS, BODY, +) must be linked and working for Trans to function properly, earlier years are easier.  Also require a body lift, or hood modification.  And they love to cruise!!
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #8 on: February 24, 2011, 01:38:47 PM »
Not the 1st gen XL-7s.  5-speeds were rare, but there.
XL-7 front coils
1.5" rear coil spacers
  • 151
« Reply #9 on: February 24, 2011, 01:58:45 PM »
Can you tell me more about it?  Do you have any pictures?  Did you do the work yourself?
Offline epike7915
  • 88
  • Team Kamikaze 4x4
« Reply #10 on: February 26, 2011, 09:03:09 AM »
I was under the assumption that an Aerio 2.3 (transverse) is a "direct" swap in LONG BLOCK form.  Meaning you just need to swap over all of your accessories, intake & exhaust.  ECM & Fuel are both supposed to support the 300 extra cc's.
TEAM KAMIKAZE 4x4:
88 Zuk-"LOCKJAW" 1.6 16v, Waggy D44's w/5.38's and full spools (ft & rr), 37" Iroks w/beadlocks, 6.5 to 1 T-case.  Full hydro steering coming soon.  Eternal work-in-progress!
Daily Driver: 2000 Tracker 4x4 w/ 2.0 4 cyl. & 5 speed. (How long will it stay stock??)
