How do i know which Instrument Cluster i Have?
  • 3783 Views
« on: February 09, 2011, 07:38:19 AM »
My dash is from a 1990 samurai but my frame is from a 1988, so im trying to figure out my instrument cluster is from an 88 or a 90.....is there any way to tell?
I want to know because if its a 1990 then i dont need to get it modified for a 16 valve swap
Online ebewley
  • 6602
  • 69
Re: How do i know which Instrument Cluster i Have?
« Reply #1 on: February 09, 2011, 08:04:44 AM »
Round vents would mean 88 and older dash. Square vents would mean 88.5 and newer... There are other differences too but this is the quickest id method.
« Reply #2 on: February 09, 2011, 08:50:55 AM »
I know the dash is 1990 cause of the dash vents like u said and the vin...but I don't know if the speedo is from 1990 or the 88 model...thanks for the help
« Reply #3 on: February 09, 2011, 10:42:15 PM »
anybody know what the speedo cluster looked like from different years?
« Reply #4 on: February 10, 2011, 09:05:17 AM »
86-88 had yellow gauges and round dash vents.
88.5-95 had red/orange gauges and square dash vents.  There is no difference in the way the 88.5-89 gauges look, compared to the 90-95 (non-tach gauges/clusters, that is).  So I assume you are asking because you need to know if you have a VSS in your cluster.  I would guess you don't, but you are going to have to pull the cluster and look, to know for sure.
Just because you have a 1990 dash VIN, that doesn't mean that the whole dash, cluster and all, is 1990.  If I were guessing, I'd say they either swapped just the VIN plate to the 88.5 dash and cluster, or they swapped the dash and kept the 88.5 cluster.  But like I said, you are going to have to pull the cluster and look, to know for sure.
« Reply #5 on: February 10, 2011, 09:11:29 PM »
what does the vss look like?
« Reply #6 on: February 11, 2011, 05:39:39 AM »
« Reply #7 on: February 11, 2011, 04:27:58 PM »
thanks for the help
