towing trackers
towing trackers
tracker8wr
568
THE BIGGER THE BETTER
towing trackers
June 04, 2004, 03:46:09 PM »
is there a procedure for towing a tracker 94 standard 4x4. i know sammis u have to put the transfer in nuetral and the tranny in a gear.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
http://www.geocities.com/race8thwonder01/
http://www.cardomain.com/memberpage/769479
tracker8wr
568
Re: towing trackers
June 05, 2004, 02:00:25 AM »
i want to use a towbar help me out here i don't want to burn up my t-case. DOES ANYONE TOW THERE TRACKER WITH A TOWBAR.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
wildgoody
8134
67
Re: towing trackers
June 05, 2004, 09:05:27 AM »
T-case and trans in neutral, should tow
fine, T-case lubes from rotation picking
up oil, auto trans leave in park
Unless any one else knows from towing
I think you will be fine.
jookycola
Re: towing trackers
Reply #3 on:
June 05, 2004, 02:14:44 PM »
I was just told by Hawk Strictly Suzukis that the proper towing procedure is T-case in neutral, and transmission in 2nd gear. and if possible start the car up every 200 or so miles and run through the gears.
nuts4hotwheels
169
Black Sunshine
Re: towing trackers
Reply #4 on:
June 06, 2004, 01:08:49 PM »
According to my chilton manual there are two methods for towing a 4wd. I don't know why, but that is what the book says.
4WD vehicle with manual hubs- Method A or B
4WD vehicle with automatic hubs- Method B
Method A: Transmission lever in 2nd gear (manual trans.) or in P (auto trans.) and T-Case in N
Method B: Unlock the hubs and place the rear wheels on a towing dolly
Black Sunshine
1998 4 dr Chevy Tracker 4x2 1.6L-16V
-K&N Performance Air Filter
-Thrush Glasspack -235/75-15 Pathfinder Trail A/P Tires -Sony Xplod Cd Player -400W Visonik amplifier -2 10" Visonik Subwoofers *******************************
tracker8wr
568
Re: towing trackers
Reply #5 on:
June 06, 2004, 01:15:39 PM »
thax for th info. how about some info on lockers. on the post best lockers
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
