Metric Bolts on Line
  • 2367 Views
« on: February 21, 2011, 06:25:55 AM »
I'm needing some M12-1.25-30 bolts to mount my hitch to the 4 door, and can not find them at any of the local hardware stores. Does any one know of a good place on line to order metric bolts?
Re: Metric Bolts on Line
« Reply #1 on: February 21, 2011, 09:31:55 AM »
That's a pretty big bolt, that would be like a 7/16 in SAE, are you sure it's not a 10mm?
I just checked with mcmaster.com and the size you requested is not available in 1.25
thread, 1.75 for 12mm and 1.5 for 10mm.
I would not think they put a special thread on the mount, a standard coarse metric
would be the most reasonable for that location, reason being is the coarse threads are
not as susceptible to corrosion and dirt damage on the underside of a vehicle
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #2 on: February 21, 2011, 01:28:28 PM »
I tend to agree with Wild but you can use this clickable link..... FASTENAL
They have them and I think you can order them on-line after you set up an account. You might also check to see if there is a store close to you 1st.
« Last Edit: February 21, 2011, 01:30:15 PM by tuxblacray »
« Reply #3 on: February 21, 2011, 04:27:24 PM »
Thanks guys.... Yea, it's a M12x1.25.30. I pulled one of Godzuki II and tried it out on the 4 door. It fit fine once I got the dirt and grime out of it and took it to a local hardware shop and sized it. I actually found some at a local fastner shop here in Nashville about an hour ago.
« Reply #4 on: February 21, 2011, 09:30:11 PM »
Good deal, because I thought you might be chasing a really hard to find bolt
« Reply #5 on: February 23, 2011, 06:32:03 AM »
I was too. Normally they would send the harware when you ordered stuff like this. I dont know why they did not this time.... Oh well, problem solved....
