Another Newbie with questions
  • 2591 Views
« on: February 24, 2011, 06:43:16 PM »
Couple of questions.
I have an 88 Sami, just got it don't know crap about it.
Instrument Cluster is the standard one with out a tach. Does the cluster with a tach simply plug in or is there a difference in the wiring harness?
Is there a trim panel normally on the passenger side, below the glove box that hides the Heater Core and ECU looking thing?
Seats, I have read several post about Dodge Neon seats being used as swaps. Is there others that you guys have found to work with out a lot of fab work?
Thanks in advance.
Re: Another Newbie with questions
« Reply #1 on: February 25, 2011, 08:41:34 PM »
If yours has round dash vents, then you need to get a tach cluster from a round vent samurai.  It will be plug and play...no wiring mods needed.
If yours has square dash vents, then you need to get a tach cluster from a square vent samurai.  it will be plug and play....no wiring mods needed.
There is no panel for under the passenger side of the dash.
Neon seats are the easiest to swap in...in my opinion.
Offline Capt
  • 738
  • 28
« Reply #2 on: March 01, 2011, 09:52:40 PM »
My dash cluster (With Tach) and round vents ,had the water temp gauge crap out, which also crapped out the fuel gauge too!!: as both share a "Common choke" ( Voltage reducer").  (87 Sammy)
Now my solution was to remove the entire dash, it is not as hard as you may think!!!
I massaged the 3 center openings (2 vents 1 clock)  to accept a 3 round gauge set. water temp, oil pressure, volts.
Moved the clock to the right outboard vent opening (Its the spotters job to keep track of the route time anyway)
and installed a round "Steward Warner" fuel gauge in the left outboard vent opening. This is the only real work involved as you will have to drop the fuel tank to install the matching sending unit as the stock Sammy sending unit will not work with the Steward Warner gauge. (good time to clean out that 20 plus year old tank anyway)
Original venting was directed towards the floor area by "Bobbing" the original vent hoses as I found that you were not getting much "Fresh Air" anyway!!
If you have a "Square Vent Dash" you can go the cluster swap route with basic "Idiot oil pres., charging lights" or go on a Junk Yard Safari with a couple of your buddies (which can turn into one of those campfire stories for eternity) and "Cannibalize" a round dash unit.
CAPT
« Reply #3 on: March 27, 2011, 05:57:41 PM »
picked up a cluster off ebay. Plug in an works fine!
« Reply #4 on: March 30, 2011, 07:11:57 PM »
Was wondering the same question, however I have installed an aluminum dash. Can I just plug in either style cluster? I have two to choose from. One square with tach and one round.
« Reply #5 on: March 30, 2011, 07:16:05 PM »
What year is your wiring harness?
