Front Differential Welding?
  • 3210 Views
Offline chevymagoo
  • 18
« on: February 26, 2011, 10:26:03 PM »
Once again I got to thinking.  I was wondering if it is possible to remove the gears in the front differential and weld the spiders instead of putting in a locker   If this is possible, i wouldnt want to run the front end locked all the time so if i have manual hubs and put them on, then i could lock just one tire allowing them to not want to skip or hop like locked axles do   I am sick of getting stuck and having to be pulled out because one tire wont grab that should be getting some traction
95 Geo Tracker Hardtop Automatic 4x4 2 Door LSI  107000 miles homeade 2.5 inch lift and 30 x 9.5s
Re: Front Differential Welding?
« Reply #1 on: February 26, 2011, 10:47:10 PM »
Don't weld the front, do the rear or get a rear locker, that will get you most anyplace
Offline skitime
  • 302
« Reply #2 on: February 27, 2011, 09:27:33 AM »
While welding the front is certainly possible, don't do it unless you have driven a vehicle with the front locked.  It become difficult to turn at all.  I have a front air locker so I have it locked when necessary but can turn it off to steer.  A constantly front locked vehicle would be ridiculous in my book.
« Reply #3 on: February 27, 2011, 10:40:24 AM »
X2, If you really need a locker up front, get one from Trail Tough, and a twin stick
from Stan (37kicker) you will really love it, 2WD low is great, and you still have locked
up front for the nasty stuff.
I did Moab last year in 2WD low about 95% of the time, and clicked in 4WD only when
I could not get through a rough spot
