95 tracker on a jeep cherokee drive train ????
  • 3865 Views
Offline ColtonP
  • 147
« on: February 28, 2011, 05:27:43 PM »
 I want to take my 95 tracker and fill it with a jeep Cherokee drivetrain 4.0 transfer case transmission suspension and bother diff and brakes and steering what all would I have to do lol.      Using tracker frame etc.
1987 Suzuki samurai BONE STOCK
(SOLD)1990 Samurai 1.6 8v swap, Arb front air locker, spool rear, RRO coil suspension, Chromoly front axles, 33x13.5-15 Swampers, ARB Bumpers, Slider, fender flares, 6.5:1 transfer case, True beadlocks, 1.5" wheel spacers,Roll cage. All in all a lil over 10k in parts uuuggghhhh!!!!!(SOLD)
(SOLD) 2000 Chevy tracker, 4 door, 4x4, auto trans, 2 inch lift,265/70r16 (SOLD)
(TOTALED)1995 tracker lsi, tintop, 3speed auto trans, 2 inch lift, 2 1/2 inch exhaust, 30x 9.5 bfg a/ts, custom front bumper.(TOTALED)
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: 95 tracker on a jeep cherokee drive train ????
« Reply #1 on: February 28, 2011, 05:45:28 PM »
My 1st question would be why......  :laugh:
and then I would tell you your going in the wrong direction....
Take the Tracker and put the body on the Heep roller....  ;)
Offline ColtonP
  • 147
« Reply #2 on: February 28, 2011, 06:02:46 PM »
Cherokee aren't on frames they r unibody that's why there are no body lifts for them  :)
« Reply #3 on: February 28, 2011, 06:14:23 PM »
That's just sacrilegious  :P
« Last Edit: March 04, 2011, 06:16:41 PM by wildgoody »
Offline Jluck
  • 1389
  • 40
« Reply #4 on: February 28, 2011, 06:38:41 PM »
I hope this is just a bad joke ???
Besides jeep running gear is flat junk in the durability department. I don't see one single advantage? Enlighten me.
Offline TopHeavy96
  • 488
« Reply #5 on: February 28, 2011, 07:00:50 PM »
Better swap that long-|removethispart|@ss hood over too.  :laugh: >:D That or get a doghouse from an Astro-van!
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #6 on: March 01, 2011, 05:32:23 PM »
I take it your talking about the Grand CHOKE ME.... then. Again it would be about as easy to cut away everything but the floor pan and weld the Tracker down to it, fabricating body mounting location for added strength.
If you decide to swap the the running gear into the tracker frame you better have a machine shop at your disposal. There are no kits for such a sacreligious act. Everything would have to be custom made / designed / bolted / welded / etc.
Lay on the ground... take pictures from front to back of the CHOKE ME... and start removing units in sequence. Remove 1 and install 1 in the tracker.
Plan on spending alot of time on it and alot of $$$....
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #7 on: March 04, 2011, 09:20:32 AM »
the back of the heep motor would have to be in the dash      would it not be easier to cut the heep in half down the middle take out 8 inches and weld it back together          save the tracker its a better rig in stock form
