1.6l 16 valve swap question
  • 16 Replies
  • 7207 Views
« on: March 03, 2011, 07:53:40 PM »
How detrimental is it if I dont put a catalytic converter on my exhaust when i don the swap? The donor is from a 98 tracker
Re: 1.6l 16 valve swap question
« Reply #1 on: March 03, 2011, 10:34:04 PM »
You are going to pollute the whole planet and ruin the ozone.
Ohh, did you mean the trucklet??? Might not have as much back
pressure so your mileage might suffer a little   ;)
« Reply #2 on: March 04, 2011, 05:57:08 PM »
true dat....anyone got any easy to do tips for making it so my hood will close...im about an inch short of being able to shut it.
« Reply #3 on: March 04, 2011, 07:36:44 PM »
I guess you are putting this in a samurai?  If so, use different motor mounts.
« Reply #4 on: March 04, 2011, 10:44:30 PM »
Yea its a sammy....what motor mounts would you use? the ones from the donor look like they are the same size
« Reply #5 on: March 05, 2011, 06:31:12 AM »
The 1.3 and 1.6 mounts are similar, but not exactly the same.  On a 1.6 swap I am working on, I used the samurai engine block mount, a dodge 318 rubber mount (anchor 2265) and the samurai frame mount on the drivers side.  On the passengers side, I used the 1.6 engine block mount, a dodge 318 rubber car mount (anchor 2266) and the samurai frame mount.  This setup compensates for the taller engine (makes it so the hood will close) and the off set passengers side mount (the dodge mount is ran sideways).  It also levels the engine.
« Reply #6 on: March 05, 2011, 08:33:09 AM »
cool...ill try that. thanks
« Reply #7 on: March 05, 2011, 08:42:14 AM »
Do you have a lift on your samurai?  If not, you have to modify the samurai oil pickup tube, so you can use the samurai oil pan for clearance.
« Reply #8 on: March 06, 2011, 07:11:09 AM »
A 98 will be OBDII. It will have 2 O2 sensors. One before and 1 after the cat. If you do not run a cat, the after sensor will give false readings to the computer and possibly make it run badly.
« Reply #9 on: March 06, 2011, 07:34:51 PM »
It seems to run fine with no cat....I am topping out at like 60mph running 32" tires...that sound normal?
« Reply #10 on: March 07, 2011, 08:13:41 AM »
That seems a bit slow, but you might need to re-gear for that size tire
Offline ASI H8
« Reply #11 on: March 07, 2011, 08:22:32 AM »
I did the same swap.  As far as motor mounts I used Petro Works motor mounts and adapter plate.  I had no issue with hood closing.
I'm also running a 3.5" SR lift so I didn't have to modify 1.6l 16v oil pan.
Offline Spitfire Rick
  • 123
  • fun lovin criminal
« Reply #12 on: March 07, 2011, 10:16:45 AM »
the first time we did a 16v swap the instructions from trail tough said it might be necessary to put a spacer under the ft body mounts (by radiator) for hood clearance .we did & it worked great. if you somehow lower the engine with mounts the exaust manifold could have clearance issues
If I have to understand don't bother explaining
Offline ASI H8
« Reply #13 on: March 07, 2011, 11:13:58 AM »
I had no issue with exhaust manifold clearance.  It isn't stock and it is close, but no issues.  I'll try to get some picts posted.  It will be late next week before I get time.
« Reply #14 on: March 07, 2011, 06:17:45 PM »
I have plenty of lift...it must be a matter of the mounts.....Im chopping a hole in the hood and putting a scoop on it. As far as the top speed it does have lower gearing but i forget what seeing as it was like that when i bought it.
