SAMMY ENGINE REBUILD
  • 2457 Views
Offline BIKEBOY636
  • I LUV MY ZUBICON!!!
« on: March 06, 2011, 10:16:13 PM »
I AM GOING TO REBUILD MY STOCK 1.3 AND PUT HI-COMP PISTONS IN IT BUT WHO IS THE BEST COMPANY TO GO WITH RIGHT NOW? I ALREADY KNOW ALL ABOUT THE ENGINE SWAPS BUT I JUST WANT TO KEEP THE 1.3 FOR RIGHT NOW. ALSO WHAT ARE SOME OTHER DECENT POWER ADDERS TO THE MOTOR? HERE IS A PIC OF MY SAMMY AFTER I JUST GOT DONE WITH MY CUSTOM FAB MISSING LINK KIT ON THE FRONT. THE TIRES THAT ARE ON IT NOW ARE 32" AT'S BUT I AM THINKING OF GOING TO 34" OR EVEN 35" THATS WHY I NEED TO REPLACE MY WORN OUT ENGINE SOON.
« Last Edit: March 06, 2011, 11:10:33 PM by BIKEBOY636 »
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
Re: SAMMY ENGINE REBUILD
« Reply #1 on: March 08, 2011, 09:36:08 PM »
http://zukiengines.com/   zack is a good guy to talk to he has been building motors for years he will get you good full kits made up aruond what you plan on doing with your samurai
« Reply #2 on: March 13, 2011, 05:42:54 PM »
I would make the lower link a bit smaller, you shouldn't need it quite that high and it could make your steering a bit squirly unless you have raised the lower link as well to match.
If this is going to be a daily driver you might want to look at putting a piece of polyurethane or rubber above the upper link, mine tend to make a chattering noise when driving down the road.  You will also need a way of stopping the shackles from folding over backwards on extension.  The easiest way to do this is to add a piece of flat stock on the top of the lower link, set just far enough down that it can only fold to about a 160 degree angle instead of a full 180.
