DIY T-Case Bucket or Cradel
  • 11 Replies
  • 4299 Views
Offline lepcur
  • 19
« on: March 21, 2011, 09:19:10 PM »
Has anyone built their own? I just did alot of gearing on the sammy and I need one but can't afford the 200 bucks right now so thought I may try one. If ya got any pics. that would be great as well.  Thanks alot,   Mike
Offline ASI H8
Re: DIY T-Case Bucket or Cradel
« Reply #1 on: March 22, 2011, 05:23:22 AM »
Skyhiranger built a nice Case bucket/cradle.  I'll see if I can dig it up or shoot him a PM.
« Last Edit: March 23, 2011, 07:52:43 AM by ASI H8 »
Offline lepcur
  • 19
« Reply #2 on: March 22, 2011, 08:46:59 AM »
Thanks alot, The more ideas the better.   Mike
« Reply #3 on: March 23, 2011, 12:23:02 PM »
I built a pretty simple one out of a junk skid plate I picked up on the trail, similar to the Mighty Kong.  The main issue after building the plate was putting it back in the SJ, it was a LOT heavier and a pain to get up around the exhaust.
Offline lepcur
  • 19
« Reply #4 on: March 23, 2011, 06:31:59 PM »
Funny you mention the added weight, I went to town today and picked up a couple pieces of scrap 3/16 plate to use and I was thinking the same thing. I don't think it will add but maybe 20 pounds top.
« Reply #5 on: March 23, 2011, 09:56:08 PM »
Here is a link to a tcase skid/bucket that I made.
http://bbs.zuwharrie.com/content/topic,34346.0.html
Offline lepcur
  • 19
« Reply #6 on: March 24, 2011, 09:56:29 AM »
Sky, Thanks for the info and pics. I can't tell in the pics. on the front but I think I'm gonna try to tie in some of those bolts as well as the 3 on the rear. How has this held up for you and what gears are you runing in the t-case.  Thanks again,    Mike
« Reply #7 on: March 24, 2011, 10:00:11 AM »
I didn't tie into any of the front bolts.
I run a kicker 3 type setup (trackick tcase and samurai tcase).  I was running stock gears for a few years, then last year I put 4.16 gears in the samurai tcase.  Everything has held up fine...no issues at all.  Tying the arms together really helps strengthen the tcase.
Offline lepcur
  • 19
« Reply #8 on: March 28, 2011, 07:41:02 AM »
Hey Sky, right now I have the arms tied together and strenthed, along with the beefed up mounts on the frame and 2 bottom bolts below the output shafts and I'm thinking it will be a pia to do any more than that and get it all lined up in the bucket. I'm not a crawler but built this for tough hunting conditions, and I have the 6.5-1 gears in it, Do you think this will work as is?    Thanks,   Mike
« Reply #9 on: March 28, 2011, 07:46:16 AM »
I can't say for sure.  The reinforced arms and mounts and tying the arms together will definitely help.  The 6.5 gears put a lot of stress on the tcase and mounts.  I guess if that is all you can do, you can try it to see if it holds up.
« Reply #10 on: March 30, 2011, 03:30:09 PM »
Make sure you use lock tight on the bolts holding the transfer case into the cradle.  If those loosen up no matter how solid your cradle is you can break your t-case in twain.  Mine split right along the mounting point on the passenger side.
Offline lepcur
  • 19
« Reply #11 on: April 02, 2011, 07:49:58 AM »
Oh yea, I use it on just about everything on this rattle trap. Thanks for the input guys,   Mike
