automatic wipers in 5th gear?!
  • 2069 Views
Offline volksie
« on: March 23, 2011, 10:54:20 PM »
When I shift into 5th gear my wipers come on, when i down shift into 4th they turn back off. Anyone have any ideas or experienced this before?
I have been looking for a body ground strap and haven't found one yet so that is the first thing I am going to try.
Offline fuzzy1
  • 350
Re: automatic wipers in 5th gear?!
« Reply #1 on: March 26, 2011, 02:19:06 PM »
Well, that's a new one to me... but you're likely on the right track with grounding. Suzukis are well known for doing weird things when grounds are bad. Can't say I'd know why only in 5th, though there might be a switch for EGR etc to tell the ECU it's in 5th. Start by cleaning the existing grounds to the block & body. Adding more can't hurt. G/l & let us know what you find, I'm curious!
Non Illegitimi Conterat
Offline crgm101
  • 80
« Reply #2 on: March 27, 2011, 05:04:00 PM »
correct me if im wrong but isnt there a reverse switch and a 5th gear switch on the transmission. could that of got its wires crossed i would try unpluging theswitch on the transmission. see if that helps good luck.
Offline yzf438
  • 94
« Reply #3 on: March 27, 2011, 10:09:52 PM »
