WTB 94 tracker crankshaft
  • 13 Replies
  • 3587 Views
« on: March 27, 2011, 01:52:29 PM »
Have a busted crank I need to replace.  It is an 8 valve g16a motor.  Crank has 6 bolt holes not the eight.
Offline kreator
  • 634
  • 15
Re: WTB 94 tracker crankshaft
« Reply #1 on: March 31, 2011, 11:45:29 AM »
MAN , I WAS HOPING FOR A BETTER RESPONCE, I NEED ONE ALSO
Offline kreator
  • 634
  • 15
« Reply #2 on: March 31, 2011, 12:06:15 PM »
I FOUND NEW , YOU BETER BE SITTING DOWN $802 IN MICH
Offline Jluck
  • 1389
  • 40
« Reply #3 on: March 31, 2011, 12:12:46 PM »
A 94 with 8v?
I have a 16v crank.
Offline kreator
  • 634
  • 15
« Reply #4 on: March 31, 2011, 04:18:18 PM »
How much ?
Offline ldodge92
  • 107
« Reply #5 on: March 31, 2011, 04:40:44 PM »
I have a 1.6 8v out of a '90 sidekick.
My new addiction
Offline Jluck
  • 1389
  • 40
« Reply #6 on: March 31, 2011, 04:44:23 PM »
75 for the short block. It's a 1994 model 16v
« Reply #7 on: March 31, 2011, 06:19:05 PM »
Jluck
Yeah, my 94 tracker is an 8 valve tbi model made in canada.  I assumed though that the mfi would be the same for the same year.  Bottom end should be the same though right?  MY block is stamped G16A.
Kreator
Autozone has one for 460 and special ordered.  still looking for more options there.  they are hard to find aren't they.
« Last Edit: March 31, 2011, 06:21:36 PM by beetfeet »
Offline reese
  • 41
« Reply #8 on: March 31, 2011, 09:03:38 PM »
only $215 new from Rockauto.com not sure if its a 8 or 16v, listed for a 94. This place is the best for parts!
Good luck.
Erik in Portland
Thanks,
Erik in Portland
95 4 door
Offline reese
  • 41
« Reply #9 on: March 31, 2011, 09:06:08 PM »
oops thats for a Sidekick, the 94 tracker is listed as 8 bolt and only $180. 6 bolt not listed..
Thanks,
Erik in Portland
95 4 door
« Reply #10 on: March 31, 2011, 09:22:58 PM »
Yep, mine is the 6 bolt of course!
Offline Jluck
  • 1389
  • 40
« Reply #11 on: March 31, 2011, 09:24:29 PM »
Jluck
Kreator
I dont remember all the engine interchange or numerical coding (never kept zuki power long) but I'm sure its on here a bunch.
and I do think it's a 6 bolt
anyways its 75 bones if it will work for ya
Offline kreator
  • 634
  • 15
« Reply #12 on: April 01, 2011, 09:33:26 AM »
IS THE  FLYWHEEL THE ONLY CHANGE FROM 6 BOLT TO 8 BOLT, I TALKED TO RPM YESTERDAY AND THEY 3 LISTED ON THE WEST COAST FOR $412 AND HE SAID THEY WHERE SAME
Online Skyhiranger
  • 3734
  • 122
« Reply #13 on: June 08, 2011, 09:25:56 PM »
I know this is an old post but....
what is this "6 bolt" "8 bolt" stuff you guys keep talking about?  All 1.6 trackick engines had cranks with 6 bolts that hold the flywheel/flexplate to the crank.  If any site lists anything different (for the 1.6 engine) it is wrong.
