Having a minor brake issue
  • 2118 Views
Offline Asbury030
  • 85
« on: March 28, 2011, 05:54:57 PM »
Well I changed my front calipers and rotors.... re bled my brakes and noticed my passenger side bleeder valve is slowly leaking its not bad at all but I feel like it should not be doing so... what should I do? Would putting some teflon tape on it help... or what should I do?
Offline Jluck
  • 1389
  • 40
Re: Having a minor brake issue
« Reply #1 on: March 28, 2011, 06:01:42 PM »
it's leaking around the threads? did you take them all the way out? you might have a foreign item under the taper. you can try pulling the bleeder out clean all and re-assemble. theres no need for Teflon tape.
Offline Asbury030
  • 85
« Reply #2 on: March 28, 2011, 06:08:03 PM »
Well to be honest I didnt install them a buddy came over and did them while I was in class. But I know the new calipers did come with new bleeders... and yeah its just leaking around the threads... I wouldn't even say its leaking more of seeping, it's very slow
Offline Jluck
  • 1389
  • 40
« Reply #3 on: March 28, 2011, 06:10:22 PM »
 might be able to just back it off a bit and re-tighten.
Offline Asbury030
  • 85
« Reply #4 on: March 28, 2011, 06:11:05 PM »
Will I have to re bleed the brakes if I do so?
Offline fordem
« Reply #5 on: March 28, 2011, 07:35:03 PM »
You can't seal a bleed nipple with teflon tape around the threads - if you still have the old calipers, take one of the nipples out and have a close look at it.
The bleed nipple has a longitudinal hole drilled almost all the way through it, the threads don't go all the way to the end and on the unthreaded portion is another hole that goes sideways to meet the first hole.  The very tip is tapered and that is what seals on a matching taper inside the hole.
When you open the nipple to bleed the brake you just back it out a half turn or so so that the taper lifts off of the seat allowing fluid to flow out through the holes.  Your leaking nipple might just need to be tightened down, or it might have some sort of foreign particle preventing it from seating properly, or it might be damaged (either the nipple or the seat in the caliper).
Try tightening the nipple as the first step, if that doesn't fix it, have someone step on the brake pedal whilst you back the nipple out half a turn and then tighten it - the pedal will go all the way to the floor when you release the nipple, make sure they hold it there until you tighten.
If neither of the above steps fixes the problem have the caliper replaced - hopefully you have some sort of warranty.
