torque value of hub body to rotor bolts?
  • 2695 Views
Offline AJMBLAZER
  • 2166
  • Your mom.
« on: May 29, 2005, 01:22:53 PM »
Can anyone give me the torque value for the little 12mm bolts that hold the hub body to the rotor?
Got 1 of the Tracker hubs on the Grand Vitara, now to do the other... 8)
Offline zooky
  • 135
Re: torque value of hub body to rotor bolts?
« Reply #1 on: May 29, 2005, 01:39:34 PM »
you dont need to torque those! Just snug them down
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #2 on: May 29, 2005, 01:42:14 PM »
I took a look at the Haynes Manual and, as expected, found nothing.  My '96 GM Tracker FSM (page 4C9) indicates 25Nm or us Metrically-Challenged USAens 18 ft. lbs.
Hope this helps!
Ack
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #3 on: May 29, 2005, 01:46:19 PM »
Thanks.  I've now likely got one of the few Grand Vitaras with manual hubs anywhere. 8)
« Last Edit: May 29, 2005, 03:53:24 PM by AJMBLAZER »
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #4 on: May 29, 2005, 06:36:52 PM »
my manual hubs come off everytime i change oil, or rotate tyres, about every 5000KM or so, and i just do them up tight, sometimes if i feel like it, i use the tube gasket maker thing, but only so it seals a bit better. water gets in through the switch anyway.
i just do them up tight, and she's all go. do over tighten, or you'll just strip the bolt and have a nice time trying to get it off. (experience)
Offline sergi
  • 307
« Reply #5 on: May 30, 2005, 02:35:45 AM »
I got them first :P (joking8))
For Warn hubs its 18-25 ft ld. I'd think it would be a good reference...
« Last Edit: May 30, 2005, 02:36:32 AM by sergi »
Suzuki Grand Vitara 3dr TurboDiesel
Barcelona, Europe
Aquesta és la meva màquina. Creus que em pots seguir?
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #6 on: May 30, 2005, 02:37:48 AM »
Yeah yeah, rub it in.
Mine has Aisin hubs from Suzuki though.
Neener neener neener...
