towing Trackkick Questions
  • 14 Replies
  • 4102 Views
Offline keith
  • 1176
« on: May 30, 2004, 12:47:53 AM »
I recently purchased an 02 Mitsu Montero Sport and I am thinking of towing the Tracker behind it.  I am looking at a tow bar for the front of the Tracker.  The Montero is rated to tow 5000 lbs.  What kind of issues can I expect towing the Tracker?  Do I put the transfer case in N when I tow it?  Would I be a lot better off to rent a trailer or dolly than to tow it four down?  Thanks.
Offline Mike71
  • 1449
Re: towing Trackkick Questions
« Reply #1 on: May 30, 2004, 02:02:16 AM »
tracker will flat tow like a dream =) just pop the T case in neutral and start the car every 100miles or so
my tracker has probably a few hundered thousand towed miles on it id guess lol everything works fine
if i were u id look into a brake buddy...when u push harder on the brakes it will make the kick stop also..that way u dont burn up ur brakes it should only cost a few hundred dollars..which is cheap for the peace of mind it will give u..u can pick it up at any camping supply store
« Last Edit: May 30, 2004, 02:03:23 AM by Mhn3773 »
Offline keith
  • 1176
« Reply #2 on: May 30, 2004, 03:21:44 AM »
Why start it every 100 miles?
« Reply #3 on: May 30, 2004, 05:00:48 AM »
to lube the non turning gears
in the trans
« Reply #4 on: May 30, 2004, 10:35:50 AM »
Might as well drop the DriveLine for an extra precaution.
Offline Mike71
  • 1449
« Reply #5 on: May 30, 2004, 11:04:25 AM »
u dont need to drop the drive line like i said my tracker has a ton of miles...aswell as the millions of other trackers of various years that are being towed as we speak
the vitara/trackers are like the #1 tow vehicle now
Offline xamtex
  • 72
« Reply #6 on: May 30, 2004, 02:00:00 PM »
will the sj / sammy tow ok?will it flat tow ok with a lockright??
god must love crazy people,he made so many of them!!!
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #7 on: June 02, 2004, 02:21:52 AM »
I know guys who tow them in gear they put them in 5th and put a piece of wood between the seat and the clutch. But i wonder how good that is for the relase bearing and other parts. Even with the tranny in N ur lower shaft still kicks up oil
01 GRAND VITARA
Offline Twins
  • 68
  • Tracker?!?
    • Site
« Reply #8 on: June 02, 2004, 03:16:23 AM »
I tried to flat tow my Track with my girls XJ,  I went about 2 miles and my knuckles were white.  It pushed the Jeep all over and I felt like the Track had more control than I did.
Mine is locked in the back and the Jeep is lifted 2 1/2"s.  I'll dolly mine but flat towing didn't work well for me at all.
Hopefully you will have better luck.    :-/
91 LSI  29X11.5 SSr's 3"body-2"suspension lifts.  Rear Locker.  Cal Mini header-no cat-2" exhaust.  Viper Yellow Duraliner.  Ice cold A/C!!! 50k actual miles
Stripes (I didn't do them) ARE GONE!!!!!!!
92 GMC Typhoon my SUV for good roads...."stock"? try me.
Offline Mike71
  • 1449
« Reply #9 on: June 02, 2004, 03:18:39 AM »
see all of the trackers that i have seen towed are being towed by 29-35-45 foot motor homes lol
« Reply #10 on: June 02, 2004, 03:33:37 AM »
She just did not want her image tarnished, by being towed by a jeep ;D
Offline Twins
  • 68
  • Tracker?!?
    • Site
« Reply #11 on: June 02, 2004, 04:36:44 AM »
Yeah that sounds about right.  It must have figured that I wouldn't beat it silly on a trail ride that had all Jeeps and me,  instead it got to drive home 90 miles on 2 1/2 cyls.  Live and learn little Track............ showing up Jeeps will always be top priority. ;D
Offline Mike71
  • 1449
« Reply #12 on: June 02, 2004, 06:19:26 AM »
hey these little turds do really well running on less then 4cyl  :o
Offline Natebert
  • 1098
« Reply #13 on: June 02, 2004, 08:03:08 AM »
Always good advice.
Offline samwise
  • 9
« Reply #14 on: June 02, 2004, 11:58:44 AM »
The reason I bought my Tracer was to tow behind my
motor home. It is an older one with only a 350 Chevy
engine. So you can see I why I wanted something real
light weight to tow.
Well I just got back from an extended holiday weekend.
I flat towed the Tracker about 1000 miles (first towing trip). I put the Tcase in neutral, trans in 5th. Did not start and run the engine every 200 miles like I've read I need to do.  The trans is not turning, why do I need to lube non turning gears?
The Tcase is spinning throwing oil everywhere in there.
In fact if you think about it you are in 4wd when in neutral!
So don't do this with auto hubs. The first thing I did to my
Tracker was install manual hubs.  I also bought a spare Tcase to tear down and try to find a way to modify the shifter where I can get neutral without going into 4wd first.
Haven't got into that yet. If anyone is interested in this
modification I might be motivated to getting into it sooner.
The Tracker towed great I hardly knew it was back there,
except for uphill into the wind. My camper chuged down
pretty slow. I towed it on Interstate highway, narrow twisty 2 lane mountain roads/passes, and some of the
roughest dirt/gravel roads you have ever seen!
I just need a little more power out of my campers engine.
Samwise
