Biggest tires for a 1998 Kick Sport?
  • 1938 Views
Offline Dennis .89-
  • 54
  • I Owe I Owe, So Off To Work I Go!!
« on: April 02, 2011, 09:32:58 PM »
i currently have 30" Dynapro m/t's and there really deep thread disene and
i like them allot but i recently cut out my wheel wells and am planning on getting
a set of interco LTB 34X10.50-16LT  what do you guys think? i also have 2" wheel spacers
oh i should also add i have a 3" suspension lift and a 1" body lift w/ wheel wells cut out quite a bit.
Re: Biggest tires for a 1998 Kick Sport?
« Reply #1 on: April 03, 2011, 12:37:29 PM »
It's going to be tight, figure you are going to need an additional 2" of clearance for the larger tires over what you have now.  What is the distance from your tire to fender at it's closest point?
Offline Dennis .89-
  • 54
« Reply #2 on: April 03, 2011, 03:56:47 PM »
im pretty sure when i measured i check from center of the hub to the fender was 19" and the radius of a 34" is 17.04"
but the only problem i was thinking is when turned and hit a bump or when i turn i don't know how much extra room i have worst case is ill have to add another body lift from 1-3" but i cut the fenders quite a bit because i don't like body lifts.
