Replacing Supplemental Restraint components
  • 2552 Views
Offline bowloco
  • 9
« on: April 04, 2011, 09:30:58 PM »
I need to replace my supplemental restraint components due to a fender bender that activated my passenger airbag. I pulled a dash from a 1997 Geo Tracker with airbags. Unfortunately, the wiring harness was cut in order to pull the dash by someone "helping" me. I went ahead and pulled the module/harness. I've been told that I need to match the module to the module (all components) with my vehicle. What do I need to do? HELP!!
Offline CAMISAMI
Re: Replacing Supplemental Restraint components
« Reply #1 on: April 05, 2011, 10:56:29 AM »
I have not worked on a tracker system but ford's can be replaced indiviually as long as they are the correct ones for the vehicle. so as long as the airbag is the same[ crosses over] it can be installed in another, the same goes for the control module. THEY MUST BE FOR THE SAME VEHICLE/OPTION PACKAGE.usually a bodyshop or junkyard will have the crossovers for each vehicle.
Offline Trackerprts
  • 106
  • Aiirbag
« Reply #2 on: April 06, 2011, 09:56:22 PM »
The module and airbags should be a set so get them from one car. When the airbags go off you need to replace the module.
For the cut wires I would just solder them back together the system will do a diagnostic check and if the light does not stay on it should be good.
99 Tracker pieced together out of 3 cars.             RR Body and suspension lift ,31 10.5r15
winch bumper,rock sliders
« Reply #3 on: April 06, 2011, 11:34:31 PM »
Yes I agree that the module and the set should be from the same car. its better to find it from a junkyard. Isnt there any method to match 2 different things from 2 different cars.
« Reply #4 on: April 07, 2011, 09:26:20 AM »
How do they do it at automotive repair shops?  Replace the entire system whenever the airbags go off?
Offline CAMISAMI
« Reply #5 on: April 07, 2011, 10:53:01 AM »
On ones I have worked on if any airbag deploys the control module must be replaced, along with any deployed airbags and if they have a seperate accelerometer[crash sensor] it may need replaced also. these do notcome as a matched set so they can be mixed and matched to a certain extent.
