Dumb question #4
  • 2699 Views
Dumb question #4
« on: April 15, 2011, 09:33:40 AM »
Anybody know if the wheel "flange" will interchange between a 'kick and a Sammi? Trying to "po' folk" a Sammi front axle into something that I can use.
Re: Dumb question #4
« Reply #1 on: April 15, 2011, 10:22:02 PM »
Are you talking about the lockout hub?
Yes but you might need an extra gasket if it's too tight
« Reply #2 on: April 16, 2011, 06:55:00 PM »
No, not the lockout, but the actual "hub" that the bearings go into and the rotor slips on to before you bolt the wheel on to it. I have one that I can post up to show what I am asking about if that would help...?
Offline sprocket
« Reply #3 on: April 22, 2011, 01:01:51 PM »
Kick and Sammy will NOT interchange.
Sammy uses old style trailer style bearings that you need to pre-load then back off 1/4 turn... the track/Kick hubs use a 2 row torque to load system that torque to 150+ ftlbs.
« Reply #4 on: April 22, 2011, 01:12:53 PM »
 Yeah, that was what I was kind of putting together.  >:(  It is amazing how hard it can be to track some these odd parts down. I am thinking that maybe I should sell the mostly there Sammi axle and just go run down an old CJ axle. THOSE are all over the F'n place around here...
Offline Capt
  • 738
  • 28
« Reply #5 on: April 22, 2011, 05:00:36 PM »
FYI,
To "SET" Sammy front wheel bearings;
Make sure to remove & tie off brake caliper.
1st torque to 57 ft lbs while turning hub in a forward rotation,   back off just enough to release "Load"
2nd Re-Torque to 11-12 ft lbs again while rotating hub in a forward rotation.
Secure with lock tab washer.
Set lock nut to 60-65 ft lbs. check hub rotation for smoothness,
Secure with tab on same lock tab washer sandwiched between nuts.
You should be good to go!!
CAPT
Offline airdale navy
  • 82
« Reply #6 on: April 22, 2011, 05:29:10 PM »
The only dumb question is the one not ask!
91 sidekick,8v,sky 1.5 lift,235 tires,full synthetic oils !GM alternator upgrade.Ford Mustang coil.4DR front brakes.
