Tires wear and rim combos.
  • 14 Replies
  • 4468 Views
Offline Speedracer7c
  • 2210
« on: May 28, 2004, 11:16:53 PM »
I am going to get the superswamper tsl radials, 31x9.50x15. I was wondering if anyone knew what the tread life would be on a kick. With about 75% on road and 25% off road driving. Also I am going to get new rims too. I was thinking about 15x7 with a 3.75 inch backspace. Would this setup cause my tires to stick out really far? Thanks Andrew
Offline 1bigtracker
  • 3409
Re: Tires wear and rim combos.
« Reply #1 on: May 28, 2004, 11:19:36 PM »
he has seen the light people.  ;D
stu
Offline explosivo
  • 3157
« Reply #2 on: May 29, 2004, 03:14:08 AM »
Shouldn't stick out more than a couple inches... my 33x12.50's on 4" backspaced wheels stick out about 4" on each side.
omghi2.us[/url]
95XL7
« Reply #3 on: May 29, 2004, 05:25:18 AM »
I'm running 15 x 7's with 3.75" back spacing. Stick out about 1.5" past the wheel wells. You can see the tires out the side mirrors when cruising down the freeway,kinda like it that way.
  • 2210
« Reply #4 on: May 29, 2004, 01:25:29 PM »
What size tires are you running now?
« Reply #5 on: May 29, 2004, 07:31:16 PM »
Around here you can run with 1 tread
sticking out of the wheel well, this was
told to me by a buddy of mine who is
an X-Cop, now a Fed Police Officer.
He says "that's why I run Boggers,
the first tread is 6 inche's wide"
;D
  • 2210
« Reply #6 on: May 30, 2004, 02:37:51 AM »
i'm going to have to buy some flexy flares like heather has on her kick. They look decent and don't cost too much.
  • 2210
« Reply #7 on: May 30, 2004, 04:16:10 AM »
I just priced out my rims and tires from 4wheelparts.com and it came to $838!!!! HOLY POO!!! Thats waay too much money. Oh well....will a 9.50 tire fit ok on a wheel with stock backspacing without rubbing on the inside of the wheel well?
Offline ArkansasTracker
  • 85
« Reply #8 on: May 30, 2004, 11:53:40 AM »
I'm running 30X9.5s on the stock rims.  I have some rubbing when turning sharp.
I'd guess the rubbing would be just a bit worse with the 31s.  Good luck!
J
'96 Soft Top Geo Tracker, auto (leaking), coil spacers, 30X9.5 Mud Rovers
Offline 92Sidekick4x4
  • 1456
« Reply #9 on: May 30, 2004, 03:49:12 PM »
i got 30x9.5s and mins totally stock mine only rubs when i turn the wheel as far as it can go, whihc i rarley ever do, they fit fine on my stock wheel.
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #10 on: May 31, 2004, 12:43:49 PM »
GOLDEN  ;D
steveo
Offline trackermad
  • 150
« Reply #11 on: June 01, 2004, 02:23:08 AM »
Hey Speedracer You need to take a trip up to Woodstock.  There is a place up there called Stans tire barn hes got tuns of used wheels.  Last time I was up there steels were 15 a piece.
"First of all: what is work? Work is of two kinds: first, altering the position of matter at or near the earth's surface relatively to other such matter; second, telling other people to do so."  ~Bertrand Russell
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #12 on: June 01, 2004, 05:17:21 AM »
Im running 30x10.5 with 2.75" back space. I also have the calmini 3" and had to trim in the wheel well. ;D
Offline OneBadZuk
  • 30
    • American Mobile X-ray
« Reply #13 on: June 01, 2004, 03:52:07 PM »
i just installed my 31x10.50 on 15x7 with 3.75 backspacing on my sidekick 2-night, fits AWSOME!!!!
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
« Reply #14 on: June 01, 2004, 04:52:14 PM »
Man here in canada if ur tires sticks passed ur fender ur car is pulled off the road. Ive seen a few guys get pulled fuckin dumb coppers
01 GRAND VITARA
