Running 32s
  • 1721 Views
Offline TrackerJoe
  • 32
Running 32s
« on: April 19, 2011, 01:18:04 PM »
Is it possible to run 32x11.5 on Dodge "Hurricane" rims with a spacer lift and fender cutting?
1997 Tracker 5 speed 2WD :( getting a locker and always on the lookout for parts for the 4WD conversion
Re: Running 32s
« Reply #1 on: April 19, 2011, 01:54:21 PM »
What is the backspace of the Dodge wheels? I am running the wheels straight off of my 89 Bronco, and the offset is about 3.5".  I get mild rubbing when turning since I have yet to trim the fenders back. I am running 32.11.5.15 "Mud Claws" for reference. I also have a 2" spacer lift with a 3" bodylift to make sure that I clear everything.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: Running 32s
« Reply #2 on: April 19, 2011, 02:40:11 PM »
Anything is possible with fender cutting.....  :laugh: I run 30 x 9.5 on Ford Outlaws and the rub a little with no lift. With lift and spacers 31 x 10.5 with no rub. So I say yess to the Hurricanes / 32 11.5.
But T-Rex is on the spot the more off-set you have would be the better.  In-set of the backspacing will throw the tires deeper into the fenderwells and possibly give you some caliper rub.
