shackles
  • 2114 Views
Offline woof359
  • 111
shackles
« on: April 19, 2011, 07:17:59 PM »
Im so not a fan of shackles, but if a guy just needed maybe an inch of lift wood longer shackles work or would they be more trouble than you save by not spending more on a lift kit. I have 3 inch Calmini lift, but I need another inch for bigger tires to clear the back of the fender flair in front.
CHUCK AND MICHELLE
Re: shackles
« Reply #1 on: April 20, 2011, 02:52:09 PM »
Shackles work, but I prefer spring lifts.  On the plus side they are cheap so if you don't like it then your not out a lot of money.  Remember, to get an inch of height you need 2" longer shackles.
What size tires are you going to?
Offline CAMISAMI
Re: shackles
« Reply #2 on: April 26, 2011, 10:53:44 AM »
I have 2" extend shackles and longer shocks works fine. for just 1" I would get shackles no problem.
Re: shackles
« Reply #3 on: May 01, 2011, 08:10:45 AM »
Cami what shocks are you using? I have 2 inch shackles and my shocks are stock. It limits the effect and the ride is rough as hell.
Beware of the Jeep thing, it makes it burn when you pee!!!!
Offline Foot
  • 76
  • Nothin Like It
Re: shackles
« Reply #4 on: May 06, 2011, 04:19:07 PM »
If I were gonna put shackles on a Sammi I would go with boomarang style. If not try adding exta leafs to the stock leaf pack.
HIT IT !!
