87 Sami 4 wheel drive noise???
  • 2159 Views
Offline ethienes
« on: April 20, 2011, 07:06:54 PM »
So I have a 87 Sami goes into 4 wheel drive and drives fine but when I let take my foot off of the accelerator it makes a grinding/clanging sound. Pretty loud. Anyone have any Idea what this is or how to fix it. I've driven in the snow this winter no problem going only when I slow down and no problem in 2 wheel drive. Thanks
Re: 87 Sami 4 wheel drive noise???
« Reply #1 on: April 21, 2011, 03:52:42 PM »
If it only does it when coasting you might have u-joints going out.  Climb under the rig and see if you have any play.
Offline ethienes
« Reply #2 on: April 25, 2011, 10:39:04 AM »
I checked my u joints and they seemed fine. The front drive line had a little play in it but i wasn't sure if that is normal it wasn't in 4 wheel drive when I check though now that I think about it.
Any other thoughts on anything else I should check or any thoughts on the noise.
Thanks
« Reply #3 on: April 25, 2011, 07:43:30 PM »
broken t-case mount
Offline lv2fsh
  • 312
  • 19
« Reply #4 on: April 25, 2011, 09:38:13 PM »
i vote for U-joint. Drive it in 4X4 for a while and get under and feel them. If they are going bad, they will be warm or hot. They don't always get loose.
