Adding calmini axles to a 98
  • 1707 Views
Offline Bfunk
  • 406
« on: April 25, 2011, 07:39:16 PM »
So the upgraded axles have are the four bolt style like the older kicks use.  My 98 2 door has the 5 bolt flange.  My question is, do I have to swap out the entire backing plate?  Or can I just swap out the axles and drums?  I haven't pulled them yet to compare so I thought I'd run it by you all first.  My donor vehicle is a 94 4 door 2wd, and my tracker is a 98 2 door 4x4... in case that matters too.  Thanks
Brian
Re: Adding calmini axles to a 98
« Reply #1 on: April 25, 2011, 07:44:43 PM »
The drums are the difference
Offline Bfunk
  • 406
« Reply #2 on: April 25, 2011, 07:46:04 PM »
Well that will be rallt damn easy then  ;D thanks
Brian
