tracker 1.6 8v, trans and t/case in a samurai?? (yes I did a search)
  • 9 Replies
  • 4072 Views
Offline Jluck
  • 1389
  • 40
this might be where I show my retarded side :-[ but I couldn't find any good results.
I am thinking about picking up a motor/trans/t-case-less sammy and also have a lead on a 90 tracker. (1.6 8v)
heres the big Q;  ???
what does it take to put the whole assembled tracker motor/trans and t-case in to the samurai?
if this is something I could do in a couple days until I can afford a crazy-ass build on the sammy I would consider doing it. I want a loaner rig around here and this might just fit the bill. :D
Offline djlantis57
  • 871
  • Take your chrome home
Re: tracker 1.6 8v, trans and t/case in a samurai?? (yes I did a search)
« Reply #1 on: April 26, 2011, 06:24:15 PM »
It'd be less work to just pick up the 90 tracker and put a sammy axle under it.  Fabbing suspension mounts is probably easier than engine/trans/t-case mounts :laugh:
Or, maybe I'm just biased because I think sas'ed trackkicks are awesome  8)
Offline Jluck
  • 1389
  • 40
« Reply #2 on: April 26, 2011, 06:31:44 PM »
Are the motor mounts different from the original 1.3 to the 1.6 8v?  And the tracker is rusty and I really want a Sammy next. ;)
Also: my audikick will be my sas'd trackick. Sooner or later
« Last Edit: April 26, 2011, 06:33:25 PM by Jluck »
Offline Jluck
  • 1389
  • 40
« Reply #3 on: April 27, 2011, 09:01:48 PM »
nobody ??? has done this?
« Reply #4 on: April 27, 2011, 10:19:59 PM »
 Hey, Jluck... Smack yourself for not thinking about a place called Izook...  Was there earlier tonight and guess what I found info on...  ;)
Offline Jluck
  • 1389
  • 40
« Reply #5 on: April 28, 2011, 09:17:47 AM »
well post me a link already! now I cant see straight too find it my self.(hit self a bit too hard). :P
Offline Jluck
  • 1389
  • 40
« Reply #6 on: April 28, 2011, 09:40:49 AM »
well I looked and still came up short (I know...I know...). all I found was 16v stuff and going to a sammy trans. I just want to flop in a assembled tracker set. (motor,trans,t-case) and go.
I even spent a few minutes on "the other zuki" forums looking.....I feel dirty and need to shower now. :P
I'm a thinkin that there will be some tunnel clearance issues but that should be it?????????
« Last Edit: April 28, 2011, 09:45:23 AM by Jluck »
« Reply #7 on: April 28, 2011, 02:18:00 PM »
I remember that there IS a need for tunnel "helping" unless you run a B/L.
Offline djlantis57
  • 871
« Reply #8 on: April 29, 2011, 05:17:26 PM »
Hmmm good idea JLuck.  It will provide a shorter overall powertrain and give you a longer rear driveshaft.  Which would be good if you plan to go sky-high...or make an excellent choice to install a doubler (OTT or otherwise)!
Offline Jluck
  • 1389
  • 40
« Reply #9 on: April 29, 2011, 09:35:59 PM »
I am trying to talk myself out of starting this project. them damn voices in my head keep arguing.
build samurai or build kick to the ultimate????
maybe neither......money situation has really taken a 180* turn lately. not looking too good. :(
