Spacer installation order of operations...
  • 2264 Views
« on: April 26, 2011, 07:45:15 PM »
Hi all,
Installing some of Jeff's spacers and am wondering how I should go about it.  Do I leave the stock rubber spacer where it sits (stuck in the spring seat) or take them out and put them between the spacer and the spring?  Does it matter?
Also, anyone know a good source for camber bolts?
Thanks,
Dan
Offline rascott
  • 669
  • 15
Re: Spacer installation order of operations...
« Reply #1 on: April 27, 2011, 06:24:08 AM »
i suggest you leave the rubber cushions where they are. i originally removed them from the front, but replaced them the next time i had the front end apart. it's possible you may add/remove for leveling.
once you learn how to deal w/the front springs it's not that bad.....
any good parts store should have(or get) camber bolts.
i like jeff's stuff.
« Reply #2 on: April 27, 2011, 05:34:44 PM »
Thanks! That is how I did it.
Now, do folks generally elongate the snubbers when adding the spacer lift?
Thanks again,
Dan
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #3 on: May 04, 2011, 02:16:20 PM »
Thanks again,
Dan
If you decide to, this is a pretty easy way to go about it.
http://www.amazon.com/gp/product/B00387A7AK
XL-7 front coils
1.5" rear coil spacers
