Goin to convert my sammi to EFI
  • 1655 Views
« on: May 02, 2011, 10:40:24 AM »
Thinking of using side kick or swift Anyone done this? Tired of carbs. Want something different.
Re: Goin to convert my sammi to EFI
« Reply #1 on: May 02, 2011, 11:48:46 AM »
Should work fine, just get the intake and distributor, might need the drive housing too
then get all the harness and ECU from a TBI Track/Kick and the electric pump should be
a frame mount from another vehicle, like they use with a 16V 1.6 conversion
Good Luck
Offline Jonny Rash
  • 1094
  • 21
« Reply #2 on: May 02, 2011, 11:51:34 AM »
If you are going to do, go with the 16-valve.  I don't think the TBI 8-valve gives that much better performance over the stock 2-barrel carb and is not worth the extra time and $$$ to convert IMHO.
