89 tracker efi to carb swap
  • 2491 Views
« on: May 04, 2011, 01:34:37 PM »
Hi all.
Newbie to your forum.I like what I  see.
I have an 89 tracker 1.6l 8v engine.It has a throttle body injection.
Does anyone here know of a carb. to swap that will bolt directly to the TBI manifold.
I do have some alum. plate and could fabricate an adaptor.If needed.
What Iam looking for is someone that can say an 1982 Toyota Corolla with a 1.8l auto will work. example only.
My problem is I do not want to do a bunch linkage / throttle cable re-routing.
My end goal is to get rid of electronics / ecu.
Where I ride at"River Ranch Fl." has lots of deep water,deep enough to submerg the ECU.
One more question is the distributor "housing" the same for my 89 1.6l 8vlv as the 1.3l Samurai?
Thanks
Randy
Offline Jluck
  • 1389
  • 40
Re: 89 tracker efi to carb swap
« Reply #1 on: May 04, 2011, 02:06:07 PM »
I do believe you can use a intake off a 1.3 and it will bolt directly on. you can post in the classified section and probably find someone willing to trade complete set-ups. most people want to go away from carbs.
