No dash lights
  • 1968 Views
No dash lights
« on: May 05, 2011, 01:49:57 AM »
I could use a little help. I have a 2002 vitara, 2 liter, auto, 4x4, 4 door. I have no dash lights. The radio was ripped off from the PO. I put a factory (junk yard) in it and it works OK. But when it's dark out the display goes out. I know I have a ambient light sensor, so maybe all I need to do is figure out how to get the dash lights to work... I'm thinking that I should start at the Dash light dimmer reostat. If I have no luck there I'll look at that ambient light sensor. Has any one had similar problems? I would also like to disable the DRL feature. Any advice???
Offline hcgalvin
  • 1695
    • Granite Path
Re: No dash lights
« Reply #1 on: May 05, 2011, 09:17:00 AM »
Are you saying you have no dash lights, period? Not even on your gauge cluster? Or are you talking about just the stereo?
If you don't have any dash lights at all, did that happen when you pulled the plug for the DRL in the other post?
Heather Galvin
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: No dash lights
« Reply #2 on: May 06, 2011, 12:47:16 PM »
First things first, make sure your taillights work / TL fuse not blown.
XL-7 front coils
1.5" rear coil spacers
