Tracker Brakes
  • 2819 Views
Offline Speedracer7c
  • 2210
Tracker Brakes
« on: May 30, 2004, 02:50:36 AM »
Well today, my stepdad was moving my tracker and said he almost drove it into the wall in the yard.... I guess I'm just used to the brakes that way. How far is the pedal going on everyone elses trackicks. thanks Andrew
Offline Mike71
  • 1449
Re: Tracker Brakes
« Reply #1 on: May 30, 2004, 02:55:03 AM »
my brakes are really really touchy..when i first started driving it i keepet locking them up since i was used to the GV
  • 2210
Re: Tracker Brakes
« Reply #2 on: May 30, 2004, 02:56:14 AM »
Guess its time to start taking them apart to see whats going on in there.
Offline jerryp58
  • 449
Re: Tracker Brakes
« Reply #3 on: May 30, 2004, 03:26:08 AM »
Sounds like a plan.
I don't think the pedal moves an inch on mine before the brakes start engaging.
I'd at least start with an inspection of the MC, lines, calipers, and pads to make sure everything looks good (no leaks or super worn pads).  If nothing jumps out at you, maybe you can get away with a good bleeding.
Good Luck.
Jerry
  • 2210
Re: Tracker Brakes
« Reply #4 on: May 30, 2004, 04:13:34 AM »
I have always wondered about my brakes. I should probably fix those before I get my rims and tires.
Re: Tracker Brakes
« Reply #5 on: May 30, 2004, 04:57:52 AM »
Sounds like the rear adjusters not
taking up the slack
95XL7
Re: Tracker Brakes
« Reply #6 on: May 30, 2004, 05:04:28 AM »
Have you been using your emergency brake?? It keeps the rear brakes adjusted.
  • 2210
Re: Tracker Brakes
« Reply #7 on: May 30, 2004, 05:35:48 AM »
I use it not a lot though.
Offline 1bigtracker
  • 3409
Re: Tracker Brakes
« Reply #8 on: May 30, 2004, 08:09:42 AM »
i can press the pedal almost to the floor tne the brakes come on hard.  wander whats up with that.  it wasn't like that last year.  i just barely put new front pads on.
stu
  ÂÂÂÂÂÂÂ
