4.3 swap in my 95 tracker. REQUIREMENTS???
  • 9 Replies
  • 17507 Views
Offline ColtonP
  • 147
« on: May 09, 2011, 04:20:36 PM »
if i was to find a decent shape s10 blazer with a good running 4.3 and automatic transmission. What else would i need to swap all of it in to my geo tracker. How does everything hook up? computers? 4x4 etc?
1987 Suzuki samurai BONE STOCK
(SOLD)1990 Samurai 1.6 8v swap, Arb front air locker, spool rear, RRO coil suspension, Chromoly front axles, 33x13.5-15 Swampers, ARB Bumpers, Slider, fender flares, 6.5:1 transfer case, True beadlocks, 1.5" wheel spacers,Roll cage. All in all a lil over 10k in parts uuuggghhhh!!!!!(SOLD)
(SOLD) 2000 Chevy tracker, 4 door, 4x4, auto trans, 2 inch lift,265/70r16 (SOLD)
(TOTALED)1995 tracker lsi, tintop, 3speed auto trans, 2 inch lift, 2 1/2 inch exhaust, 30x 9.5 bfg a/ts, custom front bumper.(TOTALED)
Re: 4.3 swap in my 95 tracker. REQUIREMENTS???
« Reply #1 on: May 09, 2011, 08:13:03 PM »
I know someone has a better answer, but I will start it off. You need lots of time, patience, and $$$. There might be lighter options.
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #2 on: May 10, 2011, 09:40:01 AM »
if you cant  do body work i would not even try it you will have the cut up the trans tunnel no it wont just plug in you will have to wire it to run its not easy for most people good luck
Offline Foot
  • 76
  • Nothin Like It
« Reply #3 on: May 10, 2011, 05:49:52 PM »
Someone on here done one a few years back. You might check archives or PM one of the mods.
HIT IT !!
Offline Jluck
  • 1389
  • 40
« Reply #4 on: May 10, 2011, 09:03:48 PM »
this is a pretty involved swap really. I don't know if there is a readily available gm-to-kick t/case or not but the OE (4x4) gm is driver side diff so the factory t/case is useless unless you do a sas too. (mo-money) also custom motor/trans mounts, major body work, alot of wiring (hopefully you would keep efi),plumbing,cooling,blah...blah...blah....
I would budget (if I were planning it)(which I never ever would) about 2500-5000. (crap adds up fast). after all that you could have a over weighted under performing kick.
(let the hate begin) ;D
my 2cents no-more no-less. ;)
« Reply #5 on: May 11, 2011, 08:07:50 AM »
I really never understood the 4.3L thing, if you are looking for more power, why not a
2.8 or a 3.1, those have a much smaller block and good power.
The 4.3 is a 350 with 2 cylinders missing, and is wide and heavy.
A 2.7 V6 from an XL7 or GV will fit better and retain the stock driveline much better
« Reply #6 on: July 19, 2011, 06:05:31 PM »
Found one on CL - not my listing, the thread just caught my eye about a Tracker with a 4.3 I found online.  Similar sheet metal, Priced a bit high.
http://tampa.craigslist.org/hdo/cto/2480910020.html
99 Tracker, Rebuilt 4.3 Vortec, Rebuilt 4l60e transmission, rebuilt Suburban transfercase, 4.88 gear ratio. Has new starter, tires 31 in,15 in rims spare rim that matches all new, fuel pump, altenator, a/c, heater core, exhaust, class 3 trailer hitch, alluminum radiator, 2.5 in susp lift, 3 in body lift, performance chip, headers, new injectors, distributor, drive shaft and lots more. Also comes with a toyota e locker rear end. 11,000 OBO may trade for black 4x4 tahoe 03 up.
« Last Edit: July 19, 2011, 06:12:44 PM by chevytracker »
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more.  95 Tracker with all Calmini bolt ons.  96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
Offline locjaw
  • 2045
  • 22
« Reply #7 on: July 21, 2011, 03:12:59 PM »
i have been telling myself lately that a 2400CC ford 4 banger might be a great weight to HP ratio conversion. i think it would be worth the machine work to mate it to a toyota tranny and tcase. There is tones of aftermarket stuff for the dirt circle and sand sports for the motor to easily get 250 Hp (with no fancy turbos and more with) and they are realitivly inexpensive to locate and work on.
yeh, yeh, let the bashing begin, but you all know im on to something  >:D  >:D  >:D
« Reply #8 on: July 21, 2011, 04:18:56 PM »
Anything but a heavy ass 4.3. There were some very good swap suggestions above, including locjaws Ford suggestion. IMO, I would go with any suzuki v6 over that lump o iron gm turd. Heavy, expensive and not a big power to weight gain.  Once again, JMO.
Locjaw, I get a catalog a couple times a year from a company that specializes in built Ford 4 bangers for racing. Just about everything you need to build a kick ass Ford engine. I'll have to look for the name in my stack of books out in the shop. I bought a lot of fittings and such for my turbo setup from them. Let me know if you decide to go that route, probably cheaper to make two of everything, and a lightweight NORMALLY ASPERATED 250HP sounds real good!  8)
Offline KJMac
  • 280
« Reply #9 on: July 26, 2011, 11:08:41 AM »
I would do the 3.1 from a camaro, they are cheap. You would then need a 700r4 from an S-10 and a 208 transfer case from
An 80's blazer or suburban, it is passenger drop. It would be more money but a Dana 300 would be better.
If you went obd 2 then there would be more wiring hassle but it would perform better. You could have the computer programmed for
A manual trans. And the vats taken out.
