o2 sensor
  • 17 Replies
  • 4608 Views
Offline mahimahimo
  • 377
o2 sensor
« on: May 25, 2004, 01:13:43 PM »
 how hard is it to change an o2 sensor on my stock header on my 94 tracker....any tips would be greatley appreciated
Offline explosivo
  • 3157
Re: o2 sensor
« Reply #1 on: May 25, 2004, 04:10:27 PM »
If it's an 8v, then it'll be as simple as having an o2 sensor socket, a ratchet, and an extension. If it's a 16v (I don't believe 94 came with them) there's one behind the catalytic convert as well as the one in the exhaust manifold.
omghi2.us[/url]
Re: o2 sensor
« Reply #2 on: May 26, 2004, 12:04:51 AM »
Unless its seized......
Re: o2 sensor
« Reply #3 on: May 26, 2004, 05:03:02 AM »
My O2 was still good, but it was the
origonal, so I thought it could use
a new one  :P  it was seized, tore
the threads out, so I had to cut a
large nut in half that had the proper
thread and weld it to the manifold.
Then the new Bosch O2 I bought
quit working in like 9 months  >:(
and had to spend another $30 to
get another one, so if yours is working
leave it to do it's job.
Offline explosivo
  • 3157
Re: o2 sensor
« Reply #4 on: May 26, 2004, 05:10:56 AM »
I guess I'm lucky then... mine popped right out and right back in... I don't believe that I used any penetrating oil, either.
That's whatcha get for having no other bolts seized up, you darned Californians ;) ;D
omghi2.us[/url]
Re: o2 sensor
« Reply #5 on: May 26, 2004, 05:21:25 AM »
 :'( I'm sorry you have rusty nuts
;D
Re: o2 sensor
« Reply #6 on: May 26, 2004, 05:29:05 AM »
Ouch :o That sounds painfull :'( You better go see a doctor for that one :P
Offline explosivo
  • 3157
Re: o2 sensor
« Reply #7 on: May 26, 2004, 07:01:52 AM »
I already have... two of them in fact. Doctor Torch and Doctor Sawzall ;)
omghi2.us[/url]
Re: o2 sensor
« Reply #8 on: May 26, 2004, 07:08:46 AM »
 ;D THAT SOUNDS EVEN MORE PAINFULL  :o OUCHHH :o
« Last Edit: May 26, 2004, 07:09:34 AM by Zukipilot »
Offline explosivo
  • 3157
Re: o2 sensor
« Reply #9 on: May 26, 2004, 07:28:28 AM »
The old rusty nuts got replaced with some shiney new ones, though. Feels much better now :o ;D
omghi2.us[/url]
Offline mahimahimo
  • 377
Re: o2 sensor
« Reply #10 on: May 26, 2004, 01:47:02 PM »
i think its siezed it wont budge and im usen a o2 socket
im letten sum penetrating oil sink in now.....would heating it with a blow torch help to loosen it up?
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: o2 sensor
« Reply #11 on: May 26, 2004, 02:16:45 PM »
It's all luck.
I was going to a new header.  So with the manifold on the workbench, several days of oiling, and heat I still pulled the threads out.
Had to buy a new one.  :o
32 MTR's Warn 8000i
Offline mahimahimo
  • 377
Re: o2 sensor
« Reply #12 on: May 26, 2004, 02:18:46 PM »
i guess time to bring it to the mechanic for $25
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: o2 sensor
« Reply #13 on: May 26, 2004, 02:25:04 PM »
If someone will do it and take responsobility for it for $25.  It just might be worth it.
32 MTR's Warn 8000i
