Removing Auto Transmission Oil Pan
  • 9 Replies
  • 3221 Views
Offline johnmckinley
  • 27
« on: May 25, 2011, 05:28:09 AM »
The Factory Service Manual says to remove the drive shaft from the transfer case before removing the pan.  Looks to me like this isn't absolutely necessary, that the pan could be snaked out of there without removing the shaft. Is this possible, or just wishful thinking?
« Last Edit: May 25, 2011, 05:44:34 AM by johnmckinley »
John McKinley
'93 Tracker 4WD Auto
Offline Foot
  • 76
  • Nothin Like It
Re: Removing Auto Transmission Oil Pan
« Reply #1 on: May 25, 2011, 07:15:15 PM »
Not really necessary but just makes it a little easier when you try to drain the fluid as the pan drops.
HIT IT !!
  • 27
« Reply #2 on: May 26, 2011, 07:20:00 AM »
Looks like you just drop the one end, not both.  Is that correct? I can see how this might avoid an ATF bath.
John McKinley
« Reply #3 on: June 01, 2011, 03:18:06 PM »
If you figure out how to drop the pan WITHOUT getting an atf bath, I'd like to know.
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #4 on: June 02, 2011, 04:01:04 AM »
drill a 1/8" hole where you can see the ridges as if it had a drain plug.
drain
remove pan and install a drain plug where you drilled hole = no mess
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #5 on: June 02, 2011, 08:22:30 AM »
drain
That's about what I did.
« Reply #6 on: June 08, 2011, 04:23:17 PM »
drain
Any leakage after putting in the drain plug?
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #7 on: June 08, 2011, 07:42:45 PM »
I can't speak for him but mine was a bit over 3 years after the install when I sold it.  No leaks or troubles.
  • 27
« Reply #8 on: July 06, 2011, 05:01:28 AM »
No leakage around plug so far. I did add RTV around its gasket just in case.
John McKinley
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #9 on: July 06, 2011, 08:05:33 AM »
drain
no; teflon washers on bung (came with assembly, 5/6 bucks at napa)
