4.24:1 gear install benefit.
  • 2583 Views
Offline rascott
  • 669
  • 15
« on: May 26, 2011, 06:04:53 AM »
interesting-
i modified and installed a '93(i believe) transfer case into my '89 kick.
since i had put on 31" tires, my speedo was no longer accurate- read low.
this corrected my speedometer reading.
i was surprised.
it's now right on the money.
Re: 4.24:1 gear install benefit.
« Reply #1 on: May 26, 2011, 08:14:46 AM »
Since the speedo drive gear is in the T-case, I would guess that one is from a Manual
trans and the other is from auto trans, that is the only thing I can think of
Offline rascott
  • 669
  • 15
« Reply #2 on: May 26, 2011, 09:54:10 AM »
i never thought to ask about what trans. the '93 case came from(my stocker is manual.).
i suspect there must be a few different speedo drives for different differential ratios?
mine are those 5.64 ones.
gee- now i can figure my mpg better.....
« Reply #3 on: May 26, 2011, 12:35:51 PM »
That would be 5.62s, they are rare, and come out of a 1.3 early sidekick
There are several different speedo drive gears, they are color coded to
be able to tell them apart, I have seen white and blue, or it could of been
beige or slightly yellow, I'm not sure, at the time I thought it was discoloration
from the oil
Offline rascott
  • 669
  • 15
« Reply #4 on: May 26, 2011, 12:50:04 PM »
thanks for the correction.
yea, i got that '89 1.3L carb model.
5.62
and both drive gears were white(or cream) colored, but i liked the results.
i was getting used to compensating for the speed difference with  my stocker, and it took me a bit to  realize i was going slower than i was used to.
i'm still slow, but happier.
richard
