WHEELS FOR SIDEKICK
  • 23 Replies
  • 10242 Views
Offline OneBadZuk
  • 30
    • American Mobile X-ray
WHEELS FOR SIDEKICK
« on: May 25, 2004, 09:31:21 AM »
Does anyone know what is the best wheel/backspace combo for a sidekick? is it 5x5.5. i want to use a 15x8 wheel, but i want it to fit the vehicle right.
Offline DaddyDave
  • 204
  • Indeed
Re: WHEELS FOR SIDEKICK
« Reply #1 on: May 25, 2004, 10:48:56 AM »
5 x 5.5 is a bolt pattern.  you would need to run a 15x7 or 15x8 (don't want to put too much stress on the CV's.  tire size is dependent on lift.  how tall are ya?
Offline OneBadZuk
  • 30
« Reply #2 on: May 25, 2004, 12:12:30 PM »
i have a 3 inch body lift, with alot of fender trimming.
it currently has worn out 30x9.50 on 15x8 chrome 5 stars. i hate the wheels (they came with vehicle) so i plan on getting some of the black "rock crawler" wheels
but i want the correct backspacing. i have a new set of 31x10.50 muds to put on the soon to be ordered wheels.
« Reply #3 on: May 25, 2004, 12:57:59 PM »
So, your looking for 2.75 inch backspacing on 15x8 rims
« Last Edit: May 25, 2004, 01:03:54 PM by trickker »
« Reply #4 on: May 25, 2004, 02:26:03 PM »
I must be a skinny rim guy, I think I
would get 7" rims for a 31 tire, I'm going
to put some street 33s on a 7" rim, and
get the backspace at about half the rim
width, so it will not stick out too far.
my 33 Swampers are mounted to a set of 2.5
backspace black Rock Crawlers, and they stick
out about 4" at the rubber knobs on the set
of LTB Swampers.
Offline OneBadZuk
  • 30
« Reply #5 on: May 25, 2004, 04:01:44 PM »
i know absolutely nothing about backspacing. i'd prefer that the wheel not stick out alot past the body, but i do want the wheel to have a lip. someone said i should go 15x8 but i'm open to whatever looks best and works best on a sidekick. does anyone have any pics with
2.5 backspacing on a 15x7 wheel? does anyone know who has the best deals on black "rock crawler" style wheel?
« Reply #6 on: May 25, 2004, 07:06:47 PM »
OK, simply stated .....
Back Spacing is the distance from
the wheel mounting surface to the
tire mounting surface (bead) so a
low # like 2.5" back space on an 8"
wheel would mean 5.5" of rim stick
out from the wheel mount surface.
I have these for the Swampers.
If you have a 7" wide rim, and back
space of say 3.5" them you would have
3.5" of rim sticking out from the wheel
mount surface, and if it were 4" then 3"
would stick out.
Stock wheels are 5.5 with 4 or 4.5 back
space, I don't remember now, I measured
this all out 2 1/2 years ago so I think I'm
doing good to get this much written  ;)
SO I like thinner rims cause they don't
stick out as much. Also I had the 33x13.5
Swampers down to almost 0 PSI (guage wouldn't
read that low) and I had no problems with
bead unseating or any adverse problems of
any kind, so do what you will, this is just my
2 cent's worth.  Ohh  4wheelparts.com had
the best price I found here in Cal, about $40
Offline OneBadZuk
  • 30
« Reply #7 on: May 26, 2004, 12:09:19 AM »
ok, so if i want the wheel/tire to not stick out that far from vehicle it would be best to get a 15x7 with a 3.5 backspacing,that would keep everything tucked in nice and pretty.
« Reply #8 on: May 26, 2004, 04:17:40 AM »
I'm going to get a set of 33s for street
and put them on 7" rims, but you need to
decide how much tire sticking out is too
much for you and back space the wheels
to that, and if you can get the wheels in
the back space you want too. You might
have to compromise
« Last Edit: May 26, 2004, 04:19:07 AM by wildgoody »
Offline OneBadZuk
  • 30
« Reply #9 on: May 26, 2004, 04:36:04 AM »
wild,
i just checked alliedwheel.com and looked up the 51 black daytona and it says the 15x7 wheel has 3 3/4
backspacing with a -6 offset and the 15x8 wheel has
3 3/4 backspacing with a -19 offset. That is the only 2 sizes they offer in that wheel in 5-5.5 bolt pattern.
So in your opinion the 15x7 wheel would be best to use with the 31x10.50 size tire. Do you think the 3 3/4 backspacing on the 15x7 wheel would keep things tucked in nice as you described above?
« Reply #10 on: May 26, 2004, 04:55:48 AM »
Sounds good to me, chech the wheels
on the trucklet before you buy them
if you can, I wish I could remember
what offset is, I'm drawing a blank
Offline Natebert
  • 1098
« Reply #11 on: May 26, 2004, 06:30:12 AM »
Offset is the distance from the center of the wheel, (inner - outer)
Like This;
« Last Edit: May 26, 2004, 06:31:51 AM by natebert »
Offline OneBadZuk
  • 30
« Reply #12 on: May 26, 2004, 11:25:46 AM »
Well i'm going to purchase the 15x7 with 3 3/4 backspacing tommorow (5-27-04). if anyone has any other suggestions or pics of this paticular combo (15x7 with 31x10.50 mudders) please send 2-night. hahaha
« Reply #13 on: May 26, 2004, 03:19:44 PM »
Here's mine on the 31 with 3 3/4 backspacing
(along time ago ;D)
Offline Breakin_Trail
  • 14
  • Gotta Love It !!!!
« Reply #14 on: May 26, 2004, 03:22:51 PM »
Stock wheels off my 1990 Kick are 4" backspace. I have 33x12.5x15 on 15x8xw/ 3.5 backspace.  I wouldn't be worried about how much they stick out as to if they will rub on the inside of the wheel well and when turning or flexing. You can get wheel spacers if they are too close to the inside.  JMO.
Grant
http://www.rocky-road.com/kickspace.html
