Service Engine Light
  • 3804 Views
Offline Jarrodl
  • 40
  • She thinks my TRACKERS sexy!
« on: May 04, 2004, 08:09:59 AM »
There was a topic that got erased during the server crash about a service engine light reset. Someone said there was a swich behind the drivers speaker. I have looked behind mine, and I can't find it anywhere. I have a 90 tracker 2dr. Could someone tell me where (top left, bottom tight, etc. ) it is and how far behind the speaker to look. Please be specific. All I see is a gold colored box and some plugs for the wiring harness. Thanks.
96 Tracker 4x4 Automatic 2dr Soft Top
Offline keith
  • 1176
Re: Service Engine Light
« Reply #1 on: May 04, 2004, 08:52:02 AM »
I can confirm that such a switch exists, but I can't tell you where it is.  The repair shop reset mine last week.
« Reply #2 on: May 04, 2004, 09:00:54 AM »
just follow the red white and blue wires ;D
Offline RifleRide
  • 29
  • Mentor a Child!
« Reply #3 on: May 12, 2004, 04:02:51 AM »
I got an 89 sidekick and that darn switch is not behind the speaker!!! It is directly under the steering column, mounted to the plastic approx. 2-3 inches from the bottom.  I finally found mine after much searching!!
Crabzuki
« Reply #4 on: May 12, 2004, 05:02:44 AM »
I simply pulled the bulb out from the check engine light,
all it is; is a dummy light. I rely on the gages, I have all gages except a pyrometer gage.
Offline Jarrodl
  • 40
« Reply #5 on: May 27, 2004, 05:06:03 AM »
I think this switch is like snipe hunting. Does it really exist?
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #6 on: May 27, 2004, 05:42:29 AM »
On my 91 4-door, I think it was right by one of the speaker mounting screws - this switch is maybe 3/4 inch long (2 cm) - it's just a little black slide-switch.
Pop the trim panel under the steering wheel, and take the speaker out - you'll find it eventually - should be real close to the surface - not buried back behind the dash.
When my 1995 2-door light went on, I had just bought it, and was driving it home from Dallas to Denver.  I didn't even stop - I popped the trim panel, and flipped the switch by feel, in the dark.
EDIT:  I guess I need to find a better place to host my avatar!  Drat!
« Last Edit: May 27, 2004, 05:44:09 AM by Bobzooki »
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #7 on: May 27, 2004, 06:04:24 AM »
I'll have to look again then in mine, haven't found it yet (92 European Vitara)....
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline Mike71
  • 1449
« Reply #8 on: May 27, 2004, 06:20:24 AM »
a 90 is diff then a 91...least i belive it is so urs may be under the steering wheel
