Suzuki Mechanic/Electrical expert needed
  • 1632 Views
« on: June 02, 2011, 12:04:22 AM »
I hava a samurai with a 1.6L 16 valve swapped into it (from a 1994 Sidekick), it has run fine for the 4 or so years I have owned it while doing regular maint.
Anyways, I have an issue where it runs perfectly fine on cold startup up to the point where it enters closed loop operation, at that point the idle slowly starts to drop down, then begins to misfire and finally will stall.
I have compression tested the motor (good), changed the oxygen sensor (was suspect because it would only stay at .8v) and changed the coolant temp and mass air flow with know good working ones without any change to my problem.
If anyone knows what might be the problem, can recommend a knowledgeable mechanic or shop to have look at it, it would be much appreciated. I m located in Vancouver BC Canada
« Last Edit: June 02, 2011, 12:05:57 AM by brian46 »
Re: Suzuki Mechanic/Electrical expert needed
« Reply #1 on: June 02, 2011, 10:04:03 PM »
Clogged/restricted EGR passages and EGR valve can cause low idle and stalling.  There are passages that run from the exhaust manifold, over to the EGR valve and from the EGR valve into the intake manifold.
Have you checked the codes, to make sure there is none showing up, other than the "12" (which means everything is ok)?
« Reply #2 on: June 02, 2011, 11:02:27 PM »
Thanks for all the ideas, but all the simple things had already been tried. ECM is/was the problem
« Reply #3 on: June 03, 2011, 07:03:40 AM »
Hmm, interesting.  That isn't a common bad ECM symptom.
