Samurai Electric Fan
  • 11 Replies
  • 5291 Views
Offline DaddyDave
  • 204
  • Indeed
« on: May 25, 2004, 08:11:48 AM »
Is it possible or has anyone run a high performance electric fan in their Sammy?  Just curious.
Offline Cwkick
  • 888
Re: Samurai Electric Fan
« Reply #1 on: May 25, 2004, 09:01:38 AM »
I put one on an early 88 that I had a while back.
It was a 10" fan with a built in shroud.  No a/c on the Sami.
In very hot weather while out wheeling it kept the Sami cool.
I sold the Sami to a friend of mine and the fan still works great.  You will get many different stories on electric fans.  I was happy with it.  ;D
Cwkick
Offline DaddyDave
  • 204
  • Indeed
« Reply #2 on: May 25, 2004, 09:15:27 AM »
did it basically fit in the stock location without any major fab work?  just curious.  Thanks for the help.
Offline Cwkick
  • 888
« Reply #3 on: May 25, 2004, 09:28:04 AM »
The one I put on, I did no fab work to it.  It was almost a perfect drop in.  It has a thermostat on it so it automatically comes on.
I don't have any pictures of the install.  I can get a picture of the finish product.
I bought the fan at a closeout store so I don't know what brand it is.
I know this isn't much help.  :-[
I can say the fan works great.
Cwkick
Offline 1bigtracker
  • 3409
« Reply #4 on: May 25, 2004, 09:52:54 AM »
i will be putting one on my sammy in the coming months and might just be pulling a fan out of a junk car to cool it.  i sure that it won't be hard to hook up and put on the rad.
stu
Offline DaddyDave
  • 204
  • Indeed
« Reply #5 on: May 25, 2004, 10:47:26 AM »
cwkick, post a pic if you can.  that would be great.
Offline trialspro
  • 149
  • 1984 suzuki sj410 lwb, spoa... rusty
« Reply #6 on: May 25, 2004, 12:33:15 PM »
why do you want electric? so you can turn it on when it gets hot manually?
ive heard from a few people engine driven fans work much better... not sure though, plus they probably dont hit the same rpm
Andrew
Offline jerryp58
  • 449
« Reply #7 on: May 25, 2004, 12:43:00 PM »
Not a Sammy, but this may be of some interest in case you missed it...  http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=suzuki_talk;action=display;num=1085267357
Jerry
Offline shoyrtt
  • 161
« Reply #8 on: May 25, 2004, 01:00:18 PM »
I have read that Sami cooling issues can be solved with a new fan clutch. I have seen vendors listing them for $100. :P As we start reaching tiple digits here in So Cal, the question remains, which option is going to cool better? If the electric fan goes out, what can you do? Just a couple of things to consider. :)
« Reply #9 on: May 25, 2004, 01:08:05 PM »
Andrew
It basicly helps in deep water crossings. If you can't shut off your fan, the water will make it flex into the Raditor.  I guess ;)
Offline DaddyDave
  • 204
  • Indeed
« Reply #10 on: May 27, 2004, 05:03:04 AM »
so basically you just bolt the elec. fan to the radiator and remove the stock crank fan right?  just checking!
Offline Cwkick
  • 888
« Reply #11 on: May 27, 2004, 05:34:49 AM »
That's what I did on mine.
I will take some pic's this weekend.
I don't know how well you will see anything.
Cwkick
