CALMINI SOLID AXLE SWAP SYSTEM
  • 2538 Views
« on: June 03, 2011, 12:40:22 AM »
I was just wondering i have the undertaker kit and put in the T case new mount in, now will that inter fear with the calmini 4 link system? from the pic's i have seen it looks as if the  4 link bolts in the same place as the undertaker kit
Re: CALMINI SOLID AXLE SWAP SYSTEM
« Reply #1 on: June 03, 2011, 12:50:31 AM »
You are treading into uncharted waters, there are very few CalMini SAS Track/Kicks
and a similar number of Undertakers out there, none of which to my knowledge
have made it into the same vehicle
You might have to contact CalMini to get a real good answer to this one
« Last Edit: June 03, 2011, 08:54:46 AM by wildgoody »
Offline Jluck
  • 1389
  • 40
« Reply #2 on: June 03, 2011, 08:21:59 AM »
and post the answer here if you get a decent one from them.
Offline DaddyDave
  • 204
  • Indeed
« Reply #3 on: June 08, 2011, 03:42:23 PM »
Do you have a pic showing the clearance on your vehicle currently with the undertaker installed?
I ask because the CALMINI kit ships with a new transmission cross-member that is also the front radius arm mount. PM me and I can send over some photos.
« Last Edit: June 08, 2011, 03:44:33 PM by DaddyDave »
