Different brand brake rotors on either side?
  • 2706 Views
« on: June 11, 2011, 05:51:28 PM »
Is it ok to fit different brand brake rotors to either side of my sidekick sport?
I ordered what I thought was a pair of brake rotors, when the parcel arrived there was only one.  I need to go on a road trip in a few days and another brake rotor from the same company won't arrive in time.  I was wondering if it would be safe to buy locally a rotor for the other side?
Re: Different brand brake rotors on either side?
« Reply #1 on: June 11, 2011, 06:38:20 PM »
I wouldn't worry unless one is special like a drilled and slotted rotor,
other than that if it's just like stock no problems, but make sure the
same pads are used as this will affect the braking performance
« Reply #2 on: June 11, 2011, 07:04:36 PM »
Thanks, yes both side pads are the same and the rotors are stock.
I removed the caliper and mounting bracket and the rotor was still stiff in place.  The manual says x2 8mm bolts are needed to remove the rotor, do the bolts push the rotor off the hub face?
« Reply #3 on: June 11, 2011, 08:17:02 PM »
I can't remember, but seems there is a screw that holds the rotor onto the hub
« Reply #4 on: June 12, 2011, 04:35:09 AM »
There's nothing but friction holding the rotor on, but sometimes they just just get stuck. The 8mm bolts are threaded into two holes on the rotor to push the rotor away from the hub, when it eventually pops off.
Offline jzap
  • 515
  • How difficult can it be?
« Reply #5 on: June 12, 2011, 07:13:07 PM »
When I warped a rotor, I replaced it with one from NAPA.  That was five years ago, and with one stock rotor and one replacement, no problem so far...
Jim Z.
66 Apache camper
« Reply #6 on: June 14, 2011, 07:53:07 AM »
Yes, the bolts just push the rotor of the hub.  But the problem is that the bolt holes/threads are usually so rusted up that you can't thread 2 bolts in there....so the threads will either strip out or the bolts will twist off.  What I do is just hammer on the backside of the rotor to drive it off....once the caliper is removed, there is room to smack the rotor with a hammer (turn the rotor a half a turn every couple of smacks and it should pop it right off).
