Samurai and Tracker Parts For Sale!
  • 2882 Views
Offline Argali
« on: June 20, 2011, 04:41:55 AM »
Huge Samurai and Tracker Part Blowout!! Many of the parts listed below are like new. Did a recent build and lots of
stuff left over from my Samurai that was built up. If you see something you want all prices are Best Offer. All prices
are plus shipping. I have Pix of everything listed below. My email is argali|removethispart|@msn.com.
1990 GEO Tracker Blue with Grey Interior (No Motor) $300
1.3 Samurai Motor $250
Tracker Soft Top White $100
1.6 liter 8 valve exhaust manifold $60
1.3 Starter Works Perfect and Like New (6 Months Old) $45
1.6 8 valve EFI Intake Manifold $250
1.6 liter 8 Valve Radiator $50
Valve Cover $25
Rear Bumper End Piece $10
Fly Wheel $35
Air Conditioning Pulley $20
1.3 liter transmission mount plate $10
1.6 liter transmission mount plate $10
GM Alternator Like New for Tracker/Samurai Including Trail Tough Bracket and Electrical Connectors (6 Months Old) $75
1.6L Distributor w/Spark Plug Wires and Distributor Cap $65
Suzuki Samurai Side Gears 22 Spline $45
1.3 Fan $25
Samurai or Tracker Seat Cushions $10
GeoTracker Hub Cover $5
Suzuki Samurai Tire Jack $10
Suzuki Samurai Throwout Bearing $10
Suzuki Samurai Transmission Shifter Knob $10
Tracker Differential Carrier $50
Suzuki Samurai Wheel Bearing Races (2) $10
Suzuki Samurai Ring Gear (2 qty.) $25 Each
Geo Tracker 2 Pin Carrier $50
2 Samurai/Tracker Bearing Adjusters $20 for Both
Samurai/Tracker Crush Sleeve and Pinion Seal (New Lowrange) $15
1.6L 8V Coil and Mount $10
1.3L Engine Mount $20
1.3L Clutch Cable Mount $20
1.3L or 1.6L Antifreeze Tank Tracker/Samurai $15
Suzuki Samurai Radio Antenna $20
Suzuki Samurai Transfer Case Flange $20
Suzuki Samurai Rear Tail Light Assembly $10
Geo Tracker Air Conditioner Compressor Mount $20
Front Right Axel Suzuki Samurai $45
Rear Bumper Piece with Led Light $10
Samurai Coil $10
2 Side Trim Pieces $10
V Belt Crank Pulley $25
2 Side Trim Pieces $10 for Both
2 Low Range SPOA Pads New $10
Suzuki Samurai 86-88 Cluster No Glass $40
Suzuki Samurai Transmission Mount $20
Geo Tracker Battery Hold Down $10
2 Tracker Motor Mounts $25
Offline Bear76
Re: Samurai and Tracker Parts For Sale!
« Reply #1 on: June 20, 2011, 10:48:39 AM »
Where are you?
Offline Argali
« Reply #2 on: June 22, 2011, 10:10:50 PM »
Maine.
Offline Texagon
  • 9
« Reply #3 on: July 01, 2011, 11:10:12 PM »
Do you have the front bumper ends?
Fat guy in a little truck.
« Reply #4 on: July 11, 2011, 01:12:05 PM »
Would u by chance have a carb for a 1.3 motor?
« Reply #5 on: July 11, 2011, 03:52:19 PM »
can you ship the 1.3 liter?
Offline proughj
  • 43
« Reply #6 on: July 14, 2011, 09:50:30 AM »
im looking for the steering shaft for a manual steering shaft also looking for the 2 bolts please pm me with hat you have
