Front axle out - safe to drive?
  • 1883 Views
Offline 3stagevtec
  • 204
  • killing two stones with one bird...
« on: June 21, 2011, 08:10:43 AM »
Can I safely drive my GV with one of the front axles out? I damaged my front differential and don't have access to other means of transport for today.. The front differential is already taken down.
Is it safe for the vehicle to drive with one of the axles out and the other tied to the vehicle?
Thanks
Offline 3stagevtec
  • 204
Re: Front axle out - safe to drive?
« Reply #1 on: June 21, 2011, 08:12:04 AM »
The front propeller shaft, out of the transfer case is also tied up.. quite securely too.. in case anyone was wondering..
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #2 on: June 21, 2011, 12:45:24 PM »
That's the only part that worries me.  I'm guessing you mean it's been pulled from the hub?  If so, you're probably cool short-term.
XL-7 front coils
1.5" rear coil spacers
Offline 3stagevtec
  • 204
« Reply #3 on: June 21, 2011, 01:50:06 PM »
Yeah, it's the right axle. The thing is stuck inside the front diff and refuses to pop out. I tried pry bars, hammering it, cursing at it etc, but nothing worked..
Will have to get a machine shop to extract it. I'm just worried about the bearing getting damaged..
« Reply #4 on: June 21, 2011, 06:45:42 PM »
If I recall correctly you have manual free wheel hubs fitted - if that is so, just unlock them and you're good to go
Offline 3stagevtec
  • 204
« Reply #5 on: June 21, 2011, 08:56:29 PM »
I have the right side front axle and manual hub off.. (I can reinstall the manual hub to prevent dirt from entering)
