fmu?
  • 1674 Views
Offline KJMac
  • 280
fmu?
« on: June 22, 2011, 12:09:19 AM »
Does anybody have an fmu for a reasonable price?
Thank you,
Kj
Re: fmu?
« Reply #1 on: June 22, 2011, 03:29:15 PM »
Hey buddy, sorry for not getting back to you sooner. I really don't think the rising rate regulator ( if that's what your looking for ) will do a proper job of fueling for your turbo application. It'll most likely over or under fuel, and probably never get to the sweet spot. You should look into H20/alcohol / or methanol injection. I built my system from guidelines I found on " Do it yourself water/methanol injection." Easy and works great.
Offline KJMac
  • 280
Re: fmu?
« Reply #2 on: June 23, 2011, 12:36:44 AM »
Bentparts,
I will look at that then! I appreciate your advice, I'm sure that is the better way to go.
Was it difficult finding the right jet size for your power application?
Thank you,
Kj
Re: fmu?
« Reply #3 on: June 23, 2011, 01:04:54 PM »
Nope, I just ordered the smallest one from McMaster Carr and it works great. The site Do It Yourself Water Injection gives complete step by step instructions, a complete parts list with numbers, and where to get everything. Couldn't be much easier. The only drawback I can see is if you use the denatured alcohol/distilled water mix ( that's what I use and it works best, but I've even used windsheild washer fluid!) it ends up costing about $7 a gallon, but it lasts quite awhile, considering your only on boost for a few seconds at a time. Check it out. Mike If you want you should start a new thread under the performance/modify section and we can continue this discussion there.
