How to?
  • 1926 Views
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
How to?
« on: May 25, 2004, 03:47:35 AM »
change rubber boots on a cv?
I try this on a 99 tracker but, any help are welcome.
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline Fredo
  • 416
Re: How to?
« Reply #1 on: May 25, 2004, 04:02:33 AM »
Offline trackermad
  • 150
Re: How to?
« Reply #2 on: May 25, 2004, 05:09:20 AM »
Your instruction page looks pretty good.  I do have some suggestions though.  You only need to take appart the inboard cv to replace both boots but if any boot is broken you should take appart that joint to clean it.  I like break cleaner for the job.  Also I tend not to bother with taking the hub appart I just pull off the hole spindle.  One other thing I always replace both boots even if only one is broken there only ten bucks and its easier to only take everything appart once.
Oh yea there is a special tool that you will need for the clamps but a pair of wire cutters may work in a pinch.
"First of all: what is work? Work is of two kinds: first, altering the position of matter at or near the earth's surface relatively to other such matter; second, telling other people to do so."  ~Bertrand Russell
