? about ROCKCRAWLER TRANSFER CASE GEARSET
  • 2170 Views
Offline Mikhail_M
« on: May 24, 2004, 04:58:21 PM »
At first, sorry for my English.
I have Suzuki Escudo, 92 and I think to buy Calmini's "ROCKCRAWLER TRANSFER CASE GEARSET"
But manager from Calmini say "However it is available in '93-'04 vehicles here in the United States"
As far as I know, in Japan of models of vehicle began to make for 1-2 years earlier than in USA. And I think my vehicle analog Sidekick after 93 year.
As far as I undestand transfer cases in vehicles befor 93 and after 93 years a different (gears have different numbers).
How can I define, did Calmini's "GEARSET" fit to my transfer case?
Can somebody name to me numbers factory's gears in transfer case, which one replace with gears from Calmini's "GEARSET" ?
Re: ? about ROCKCRAWLER TRANSFER CASE GEARSET
« Reply #1 on: May 24, 2004, 05:57:03 PM »
I have an 89' SideKick (Escudo) and I think
the gears fit mine, so you should not have
a problem with them fitting your transfer case.
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #2 on: May 25, 2004, 02:41:25 AM »
I tried to install a Calmini gearset in a 89 case once and it didnt fit. The input shaft is about 1/3 inch shorter. It looks the same but wont work. However I installed in a 91 Geo and it fit.  :-/ I belive it will work for Mikhail_M but not so sure about wild. However a newer case will bolt right in so worst case scenerio buy a newer case and put the gears in it.
Mike
« Reply #3 on: May 25, 2004, 02:52:08 AM »
I ran into that problem with my GRP 4:1. The first set did not fit, so I forwarded it to someone else in the US that was wanting a set and GRP sent me their other design and it fit fine. I do not know how to determing if it will work or not. Greg |removethispart|@ GRP was still trying to find a way externally to tell the difference back then.
« Reply #4 on: May 25, 2004, 04:43:19 AM »
Why am I always the one with the
stuff that is different  :(
Good thing I didn't buy that set and
try to go to Moab
