Installing Lincoln Locker
  • 4051 Views
« on: June 27, 2011, 01:36:31 PM »
I have an off-road only 89 Tracker.I am going to weld up the rear.I am just curious what to look for as far pulling the axles etc.
Any tricks or things to watch out for,that you guys have already been through?
Thanks
Randy
Offline mattlofbc
  • 32
  • Its a GEO thing... I don't understand either
Re: Installing Lincoln Locker
« Reply #1 on: June 27, 2011, 08:56:26 PM »
its pretty straight forward, 4 bolts on either side of the axle housing and viola... after u pull the shafts, remove the 3rd member (disconnect 4bolts from driveshaft, rear ABS sensor wire, and 4 bolts for rear upper A arm) then pull the whole member out and set it on the bench, some use different methods, but the important thing no matter how you "install" the lincoln locker is to keep the gears and bears and all parts clean.  I use tin foil and wrap bearings gears and everything to prevent spatter from sticking. Then lay in the heat, I melted all the spiders together on mine and then cut 2 pieces of plate to fit across all 4 spiders and welded it to all of them on both sides.... been 2 yrs of wheeling with 33x14x15" Pitbull rocker tires and the only carnage that I have done so far is snapped a front u-joint on the rear driveshaft... it does make an awfully attention grabbing chirp when I go around corners on pavement driving to my wheeling site (imagine an e-brake pulled at 55mph)
'93 Geo Tracker 8V
     Dana 44 SAS 4 Link - 14" travel
     33" Pitbull Rocker's
'96 Geo Tracker 16V
     Custom Bumpers and Cage      29" Goodyear Wrangler MTR's '94 Geo Tracker 8V       5" IFS frame drop and lengthen... NO rear susp or axle at all, its 2x2 off road machine lol      33" Pitbull Rocker's
« Reply #2 on: June 28, 2011, 01:14:12 PM »
if you use a wire feed welder with gas make sure you do not use carb cleaner to clean the gears, you could make fosgene gas (spell check) and possibly Kill yourself.
« Reply #3 on: June 29, 2011, 12:04:29 PM »
Thanks guys.I will get started.
Randy
Offline vw505
  • 133
« Reply #4 on: July 04, 2011, 10:33:27 PM »
I have a rear diff that is welded. Has any on driven on on the street?
« Reply #5 on: July 05, 2011, 04:44:36 PM »
They will chew up your tires, will eventually break axles, and are pretty noisy in parking lots.  But other then that they work fine.  Make sure you have good welds, pavement has a lot more traction so it so it will put more stress on the drivetrain when it's welded together.
