at my wits end
  • 2589 Views
Offline Mike71
  • 1449
at my wits end
« on: May 24, 2004, 12:20:35 PM »
ok the #2 and 3 spark plugs have come losse...so that makes 2 times for the 2nd plug and once for the 3rd..WTF is going on..the boots are as tight as u can possibly imagine adn they still shook losse...i am so lost right now...anyone got any ideas?
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: at my wits end
« Reply #1 on: May 24, 2004, 01:19:19 PM »
Uh...wrong plugs?...not torqued correctly?...bad threads?
Re: at my wits end
« Reply #2 on: May 24, 2004, 01:24:53 PM »
You mention boots, the boots won't
keep the plugs from getting loose,
do you mean the spark plug wires/boots
are coming loose ?
The wires need to click on, if they don't
click, they will work loose and fall off, then
you will loose power from cylinders not firing
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
Re: at my wits end
« Reply #3 on: May 24, 2004, 01:28:41 PM »
are coming loose ?
Yeah that's what I was trying to figure out too.  I didn't think the actual plug was coming loose.
The boot has too "click" onto the plug in order to stay connected.
Offline Mike71
  • 1449
Re: at my wits end
« Reply #4 on: May 24, 2004, 01:30:51 PM »
boots click and unclick when i take them off..the spark plug BACKS out of the hole and i get an exh. leak!!! it has happened twice..never happened before though so i replaced the plugs and wires these are like 2 days old!!!
Re: at my wits end
« Reply #5 on: May 24, 2004, 03:09:08 PM »
OK, well that's good.
The plugs should be turned about
1/4 turn after the washer touches
the head, this is a rough statement
as the plugs really need to be torqued.
Offline 1bigtracker
  • 3409
Re: at my wits end
« Reply #6 on: May 24, 2004, 03:11:16 PM »
mabey its time for a new head?
stu
Re: at my wits end
« Reply #7 on: May 24, 2004, 03:33:24 PM »
Naw, just spark plug thread inserts
Offline Mike71
  • 1449
Re: at my wits end
« Reply #8 on: May 24, 2004, 06:55:10 PM »
so ill just use lock tite for now untill the car gets to u wild? =) lol
